Heil PGAD36D1K2 Heat Exchanger Replacement Help - HVAC - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 02:41 AM   #1
Heil PGAD36D1K2 heat exchanger replacement help
I was just told I needed a new heat exchanger.
I have a Heil hvac
Model # PGAD36D1K2
MFR# PGAD36D1K
SN# L940565104
Where can I buy the heat exchanger? I need to buy one asap. Also any videos or instruction on changing it out? HELP lol
Novoken is offline   Reply With Quote
Old 11-21-2012, 05:39 AM   #2
Rewards Points: 196
Heat exchangers are not a DYI type of repair.Recommend having it done by someone with experience.
HVACTECH96 is offline   Reply With Quote
The Following User Says Thank You to HVACTECH96 For This Useful Post:
hvactech126 (11-22-2012)
Old 11-21-2012, 05:41 AM   #3
im not doing the repair. Just want to know what it takes to do it. So anyone know where to get the HX from?
Old 11-21-2012, 04:58 PM   #4
have to buy from the mfg. but once you see what it tales you may want to buy a new furnace instead.
too many diff kinds of HXs to be able to give a step by step.
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
Old 11-21-2012, 05:14 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,730
Ayuh,... It's rarely worth it to change a heat exchanger,...
It's time to buy a New Furnace.....
Old 11-21-2012, 05:38 PM   #6
Bondo, you don't say much, but when you do it's worth listening to.
Old 11-21-2012, 06:45 PM   #7
Rewards Points: 582
as mentioned its not a diy project...this has to be ordered from mfg... in most cases has to be a licensed contractor to recieve this part...and yes it is a major job......like a heart transplant.......consider new furnace...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 11-22-2012, 05:18 AM   #8
Bondo's Avatar
Ayuh,... Bein' a single digit typist, I got say alot, with few words,...
Face ta face, I'll talk Both yer ears off,....
The Following User Says Thank You to Bondo For This Useful Post:
ben's plumbing (11-22-2012)
Old 11-23-2012, 05:07 PM   #9
Rewards Points: 484
The PGAD is a package unit, much easier to replace in most cases than a furnace. Is it on a roof, or on the ground?
sammy37 is offline   Reply With Quote
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
Heil heat / air unit jimseng HVAC 4 11-25-2011 03:48 PM
Rheem Heat Exchanger Noise Vulcanus HVAC 0 12-19-2010 10:42 PM
Old Armstrong Heat Exchanger (Qs with Pics) steveel HVAC 9 12-03-2010 03:36 PM
Service tech won't repair furnace with cracked heat exchanger. GloBigRed HVAC 16 11-18-2010 02:27 AM
