Heil Ntg9125 Startup Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2011, 01:12 AM   #1
hwy
Heil ntg9125 startup issue
My exhaust blower makes a rumbling noise when starting, ignites, blower motor kicks on, it blows hot air...the problem is the rumbling continues and then it pulsates. My guess is the exhaust blower needs replaced or could it be something else. Is it ok to run, I did shut the thermostat off. Any suggestions?
hwy is offline   Reply With Quote
Old 12-27-2011, 03:12 AM   #2
you are correct, that motor has to go.....keep in mind the amount of work that motor does, it is responsible for drawing in the combustion air as well as making the pressure switch and expelling the exhaust gases, it spins at 3100 to 3500 rpm, your car engine isn't spinning that fast at highway speeds, it deals with temperature's above 300 degrees as well.
harleyrider is offline   Reply With Quote
Old 12-27-2011, 09:03 AM   #3
REP
From your brief discription it sounds like the little blower wheel on that vent motor is also am little off balance too.This means that you should get the venter assy and not just the motor. That will make an easier job of it too. Good Luck.
REP is offline   Reply With Quote
Old 12-27-2011, 11:11 AM   #4
Rewards Points: 582
yes get the entire inducer assy....not to bad to change either...
Old 12-27-2011, 11:13 AM   #5
hwy
Thank you! I appreciate the advice!
how to reduce mositure issue on basement? diy001 Building & Construction 0 10-28-2011 01:44 PM
Perplexing AC issue AvalonGirl HVAC 22 08-17-2011 07:49 PM
Ceiling issue wooten General DIY Discussions 5 06-06-2011 08:20 PM
Flood/Drainage Issue On Garage Man Door altc81 Building & Construction 2 04-17-2011 09:19 AM
Heating Issue! not mechanically inclined HVAC 3 11-09-2007 10:40 AM
