Heil NG Furnace - Combustion Blower Never Turns Off - HVAC - DIY Chatroom Home Improvement Forum
Old 06-10-2010, 03:56 PM   #1
Heil NG Furnace - Combustion blower never turns off
I have an investment property with a Heil Gas furnace and split A/C unit that appears to have been installed sometime around 2001.
The combustion blower on the furnace runs anytime the breaker feeding it is on. This happens even if I remove the thermostat from the wall plate, so I feel sure it's something internal to the furnace/air handler.
Any suggestions before I call a pro? e.g. reset switches, cheap and easy parts to replace or clean?
Thanks!
Heath
PHRoberts is offline   Reply With Quote
Old 06-10-2010, 05:27 PM   #2
An old Tradesmen
Rewards Points: 8,170
Air filter probably wasn't changed often enough. And now the high limit is stuck open.
Old 06-10-2010, 06:36 PM   #3
I agree with beenthere "IF" it is the actual supply air blower that is always on when there is power to the unit. That is the default when the high-limit switch is tripped as a safety feature to try to keep the heat exchanger from getting to hot.
The way the question is worded though, makes me think it may be the draft inducer fan that is running constantly. If that's the case it could be a stuck or otherwise malfunctioning relay or possible control board problem.
Marge Inoverra is offline   Reply With Quote
Old 06-11-2010, 01:25 AM   #4
It's the combustion blower that's stuck on - not the main fan that blows air through the vents in the house.
Thanks!
Heath
Old 06-11-2010, 04:37 AM   #5
An old Tradesmen
Disconnect the wire from the W terminal on the furnace board. If it still does it. Then good chance the board has a stuck relay.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Heil GNE075B12 Water in teh tube between combustion blower and pressure switch Quin HVAC 51 01-04-2013 11:46 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
