Heil N9MP1 Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 09-04-2010, 05:05 PM   #1
Heil N9MP1 not working
My ac unit isn't blowing. The outside unit is working but not the inside. I've tried bypassing the thermostat, hooked the black fan wire up to run constant, and cut the control valve off for five mins with no luck. The blower wheel is dirty, I know I should change the filter more then I do. Is there any thing else I can try to make sure it's the blower motor before I attempt to replace it. Also, there's a little box on the right side that the motor that hums alittle. I felt it so I know it's coming from it.
Bakkrkr is offline   Reply With Quote
Old 09-04-2010, 05:14 PM   #2
If there is 120 volts off the furnace board then the motor cap or motor are bad.
hvaclover is offline   Reply With Quote
Old 09-04-2010, 05:29 PM   #3
Don't have one put I might be able to borrow one. Measure the voltage where the motor plugs to the board?
Old 09-04-2010, 05:31 PM   #4
Yep....
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 03:31 AM
Heil 5000 HE unit not working oldtom HVAC 2 09-27-2009 07:27 PM
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
Furnace (HEIL N9MP1) fan runs steady Dave @ Kamloops HVAC 1 10-14-2007 07:49 PM
