Old 10-21-2011, 09:30 AM   #1
Exclamation
Heil N8MPN Fail to Ignite
Good morning,
Long time reader, first time poster here. First want to thank you for all of the great advise we've found here in the past!
Currently we are having a bit of a conundrum with a Heil N8MPN propane furnace. When the heat is turned on the inducer motor starts and after a 15 second delay a relay fires, but the igniter does not light up. We've replace it with a known good igniter, so we know that it is not a bad igniter.
Searching has not turned up any related problems and fixes that we can find. Any idea on what might be wrong or what we should try next?
Thanks in advance!
290627 is offline   Reply With Quote
Old 10-21-2011, 01:02 PM   #2
Probably should have given some more details, sorry.
  • Pressure switch is good/closing. 24v across it and to the board.
  • Limit switch is good/closing. 24v across it and to the board.
  • Rollout Switch is good/closing. 24v across it and to the board.
  • Fuse on board is good.
The black leading to the HSI is part of a duo plug on the board together with the inducer. The inducer side of the plug is getting 120v but the HSI side isn’t getting anything.
Any ideas?
Old 10-21-2011, 01:24 PM   #3
Sounds like a bad board.
Patrick Eubanks is offline   Reply With Quote
Old 10-21-2011, 07:27 PM   #4
Houston204's Avatar
Does it display any trouble codes?
Houston204 is offline   Reply With Quote
Tags
furnace, heil, igniter
Heil Furnace issues KMV HVAC 5 12-09-2010 02:37 PM
Heil Gas Pack Burner Issue Howard99 HVAC 14 12-04-2010 07:30 AM
Heil furnace won't ignite mjprel HVAC 24 10-23-2009 03:52 PM
Heil Help! PHOnos HVAC 40 02-24-2009 08:32 AM
Furnace fails to ignite now and then... diitto HVAC 1 01-01-2009 12:00 PM
