Heil Inducer Fan Will Not Run? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-21-2009, 06:41 PM   #16
Heil won't run
Yuri -- Thank you so much for your help -- you sound like you are an old pro. I will take your advise. I thought about last year when they put in a new fan -- and you are right, crazy money. I bought a second one this year because when I noticed the heat was not working the furnace had been trying to cycle on all night. By the time I discovered the blower motor was super hot! My assumption was that it was locked again, so I bought a new one with observed results as I have explained.
A new furnace is in order -- hopefully I will have a few good days to try and seal up the furnace room before I install it. Last question -- have you had any luck with Carrier? -- I found some 80% on sale (overstock for $500).
Thomcat is offline   Reply With Quote
Old 11-21-2009, 07:02 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 92
Yours is a 92% efficient. The 80% is mid efficient and needs a chimney. For $500 it is "freight damaged" LOL. I have seen a LOT of different units in my 31 yrs. Lennox is my favorite, Rheem is a good basic furnace IMO. The most important part is to get a reputable dealer to install a good well established brand name unit. Lots of "rebranding" these days and hard to get parts for them later. L and R don't do that or have that "problem".
Tags
80% inducer , fasco fan , heil furnace , help! , inducer won't run
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 01:50 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Inducer motor or control circuit? Please help me troubleshoot. averagerob HVAC 1 03-03-2009 01:43 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 04:56 PM
Replacement impeller and clip for Heil exhaust inducer blower iixeb HVAC 2 01-09-2009 08:36 PM
