Heil Ignition Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 11-16-2007, 12:23 AM   #1
Heil ignition problems
I have a Heil furnace circa 1990 with an electronic intermittent pilot. when the furnace tries to kick on the ignition module fires and the pilot briefly lights for a split second. then all goes dead.
I've checked for voltage at the gas valve and have 24 volts on the two hot wires - one is only hot during spark off (or is it spark on, can't remember). the other on stays live when I unplug it, and there's a constant humming sound until i plug it back in.
anyway, it's as if the pilot gets a short shot of gas, then goes out. then the thing tries to fire again a couple seconds later, and just keeps repeating.
I don't see a thermocouple/flame sensor. but there must be one, right?
not sure what to do next.
sky jumper is offline   Reply With Quote
Old 11-16-2007, 01:30 PM   #2
ok, after further research & troubleshooting I've found the following:
the gas valve (honeywell 8204) appears to have bad valve coils. I ohmed them and got infinite resistance. the identical set up for the 1st floor shows about 20ohm for both the PV and MV coils.
strange thing - the pilot does briefly light. and I've verified that there is definitely a shot of gas coming out of the pilot line (smell test) - not much, and it quickly dissipates, but it's there. and yet the coil appears to be blown. how's the gas getting out??
anyway, I feel confident the gas valve needs to be replaced. any tips on how to do this??
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
This may help someone with carrier ignition problems AweMan HVAC 15 02-09-2009 02:20 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
my ac keeps blowing boards on my heil furnace sally HVAC 2 07-23-2005 08:14 PM
