Old 08-28-2009, 09:03 PM   #1
Heil HVAC unit fan won't go on help!
My coil is frozen and my fan does not go on can anybody help?
rivera76 is offline   Reply With Quote
Old 08-28-2009, 09:12 PM   #2
GC/Master Plumber/Mech
Can you remove the panels on the furnace and reach in and ry to spin the blower wheel by hand.
If it doesn't spin then the motor is fried.
If it does spin look at the control board and locate the thermostat connection terminals. Make a jumper wire and jump the R & G terminals.
You will also have to push in on the safety switch that the panel normally closes.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-28-2009, 09:19 PM   #3
Fan spin normally (by hand). Made the jumper and held the door switch and still nothing.
Old 08-28-2009, 09:31 PM   #4
DOes the control board have a LED?
If it does when you push the safety switch in does it come on?
If it doesn't check power to the furnace. If it does, does it flash or pluse?
Check also off the control board to the blower motor the cool terminal voltage. "Cool" term to ground should be 120 vac
Old 08-28-2009, 09:50 PM   #5
No LED. I need to check the power.
Old 08-28-2009, 10:07 PM   #6
we have power.
Old 08-28-2009, 10:09 PM   #7
Well you said that the coil is frozen so there is power to the furnace. Now check power to the blower motor. Normally the black wire to the motor. If you have poser off the control board to the motor. The next step is to look at the capacitor.
Does it look budged?
Old 08-28-2009, 10:14 PM   #8
If I move the black wire from cool to cont the fan goes on. Will this be ok to run this way?
Old 08-28-2009, 10:16 PM   #9
It should work as a temp fix.
Sounds like you have a control board that has gone bad.
Old 08-28-2009, 10:17 PM   #10
HvacWiz's Avatar
yes you can run it like that, sounds like you need a new circuit board.
HvacWiz is offline   Reply With Quote
Old 08-28-2009, 10:20 PM   #11
this will make the fan run continuos correct?
Old 08-28-2009, 10:22 PM   #12
yes it will
Old 08-29-2009, 09:25 PM   #13
HVAC / Plumbing
Originally Posted by Plumber101 View Post
yes it will
Not trying to hijack this thread... But , I've been away a while & just wanted to know if plumber ever got the M.H. to cooling correctly/ok
kenmac is offline   Reply With Quote
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 10:51 AM
Why is water coming out from the bottom of the HVAC unit? Woz HVAC 11 08-02-2009 09:38 AM
12 year old HVAC unit, fix or replace Miranda7 HVAC 22 05-29-2009 08:44 PM
HVAC unit moves too much air - can I slow the fan down? UtahGuy HVAC 7 12-16-2008 07:06 PM
HEIL 5000 HVAC troubleshooting tidejunky HVAC 15 03-02-2008 05:19 PM
