Heil Heat Pump Condenser Fan Blade - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 10:49 PM   #1
Heil Heat pump condenser fan blade
I recently replaced my condenser fan motor on my unit, but I had a heck of a time getting the 4 blade fan blade off the old motor, and upon getting it off I think I bent one or more of the fan blades.
I put the new motor on with the old fan and now have a pretty good vibration in it.
Is there anything I can do to determine which of the baldes are bent ?
Also, how is the best way to test the 20K heat strips to make sure the sequencers are performing as they should ?
Tim66 is offline   Reply With Quote
Old 12-19-2010, 07:29 AM   #2
An old Tradesmen
Rewards Points: 6,108
It was a balanced fan. You can't get it back to being balanced again. Get a new fan blade.
The Following User Says Thank You to beenthere For This Useful Post:
Tim66 (12-20-2010)
Old 12-19-2010, 02:51 PM   #3
How do you go about test the heat stips to ensure your sequencers are performing they way they should ? I have 20K heat, and 5 sequencers, in which way do they start up, or do they all come in on a as need basis ?
Old 12-19-2010, 03:24 PM   #4
An old Tradesmen
I turn the thermostat all the way up. And then test each sequencer with an amp meter.
Tim66 (12-20-2010)
Old 12-19-2010, 03:54 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,112
Make sure you do not stick your fingers too close as you are dealing with 240 volts and up to a 150 amp breaker to trip if you short yourself out. You will die B4 that happens.
Old 12-19-2010, 03:56 PM   #6
An old Tradesmen
Ya. You don;t want to touch any bare conductors. that would make for a sad Christmas for you and your family.
Tim66 (12-20-2010)
Old 12-19-2010, 03:59 PM   #7
Hvac Pro
yuri's Avatar
Scares the heck outta me when checking for 24 volts on the coil of sequencers and the 240 is half an inch away on the next terminal.
The Following User Says Thank You to yuri For This Useful Post:
Tim66 (12-20-2010)
How to stop auxillary heat from coming on defrost cycle and limit auxillary heat use? twilightcall HVAC 34 12-28-2010 07:53 PM
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 10:46 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
Condenser Fan Stop/Start - Heat Pump mkurley HVAC 5 02-04-2009 03:06 PM
Heat pump condenser fan missing: how do I know what to replace it with? Ptron HVAC 9 11-29-2008 01:46 PM
