Heil Heat exchanger recall
There is no RECALL on the heat exchanger. A lot of them fail from the furnace being overfired (gas pressure too high) or lack of airflow etc. You need to get an experienced ICP, Heil tech to check the unit and find out why it is tripping. The heat exchanger has a warranty but the labor to replace it is not covered.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
