Heil Heat Exchanger Gone Bad. What To Do? - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 08:29 PM   #46
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
whos bashing brands here?did you not read my post about him calling goodman an inferior brand? all i did was mentioned some of the problems other brands have to level the playing field here,install whatever you want ! i work on all brands it dont matter to me what is but for residential gas furnaces and heat pumps i personally believe the goodman is just as good if not better than any of the brands he calls superior
plummen is offline   Reply With Quote
Old 01-10-2010, 08:33 PM   #47
plummen's Avatar
Originally Posted by nichelob View Post
Type of unit: Heil GasPack
Age: 11 years old
Warranty: 10 years
Heated area of home: 1300 sq ft.
Age of house: 50 years (built 1959)
Sequence of events:
1. 1998: GasPack installed
2. 2002: I buy the house
3. 2009, December: Stops heating
4. 2009, December: I pay large company $89 to inform me that a safety switch has been triggered, which effectively shuts the unit down
5. 2009, December: Safety switch is reset, heat works fine.
6. 2009, December: Same company inspects unit and informs me that heat exchanger is rusted thru, which I verify to be true (I keep heat off to avoid CO poisoning)
7. 2009, December: Plan to make it thru winter without HVAC heat and reevaluate next winter.
8. 2009, January: Too cold. Decide to purchase new heat exchanger from Searspartsdirect.com for $350 and have licensed Craigslist guy install for $250.
9. 2009, January: Part is on B/O. Debating whether or not to purchase whole new unit.
So my questions are:
1. Should I repair or replace?
2. If replace, which brand should I get? Goodman is cheap, but would like to have a Carrier, Trane, Lennox or some other “high quality” brand.
3. If replace, how should I go about getting this done properly? (Correct sizing, quality install, etc…)
Thanks in advance! Feel free to heckle
Nick.
this whole post began with bashing a certain brand of equipment
Old 01-10-2010, 08:40 PM   #48
An old Tradesmen
Rewards Points: 6,072
he just posted his tracking of troubles and repair expenses.
We all should be proud of the brand we sell.
Just not too prideful when we sing its praises.
Old 01-10-2010, 09:05 PM   #49
plummen's Avatar
im not too proud of anything except the work i do! do you drink,im ready to buy you a beer and i dont even drink!
Old 01-10-2010, 09:19 PM   #50
An old Tradesmen
I drink very little anymore.
I tend to sometimes forget when its time to leave a bar if I go out.
But, I'll let you buy me one anyways.
Old 01-18-2010, 09:33 PM   #51
You'll probably need more than the exchanger
Sorry, this is my first post and didn't realize there were 3 more pages of replies. I see you had the cl man do the fix. Below is what i wrote before realizing the next 3 pages of posts:
If the front of your furnace area is rusted you'll need more than an exchanger.
I have the same unit, installed in 93. My exchanger just popped the roll-out switch last week. I replaced the roll out switch only to have it pop again. Pulled out the blower fan and found 5 holes in the 4 pipes of the exchanger. Not that i'm suggesting this, but i sealed them up with some Inferno 2000 deg F. I found it at AutoZone in the muffler repair section. It's basically a cold-weld that after a 4 hour cure and a 10-minute burn-in, becomes hi-temp resistant metal. Again, i'm not suggesting you perform unless you're mechanical and understand both how your heating system works and how the repair works. I bonded mine 3 days ago and yesterday opened the windows and cranked the heat for an hour to let the metal compound off-gas the chemicals.
BTW- since i've had my house, 7 yrs: I've had to bypass the compressor anti-cycle timer & replace the condenser fan motor --- so you have some more things coming.
FixItFrank is offline   Reply With Quote
Old 01-19-2010, 04:49 AM   #52
Originally Posted by SULTINI View Post
hvaclover, OH There you are I thought you got sucked into a big fan somewhere or some homeowner stopped over to say hello to you.
Missed your Picture. I'm a scare -d-cat.
Hell ....nobody knows my real name or where I live.
Even my IP number is disguised
hvaclover is offline   Reply With Quote
Old 09-02-2014, 09:38 AM   #53
Craigs list guy.
Ask guy from Craig's list to give you price to install new heater, let him do it.
Yep have the Craigslist guy do it. He can probably set you up with a goodman or something cheaper. My grandma might be available, as she can buy a goodman too.
Don't get someone with a license or a job, your warranty doesn't need a dealer and the Craigslist guy is probably insured and trained more than most licensed guys.
Homer123 is offline   Reply With Quote
Old 09-03-2014, 07:28 PM   #54
Rewards Points: 484
Well, since this thread is several years old, I'm sure the OP is long gone.
sammy37 is offline   Reply With Quote
Old 09-03-2014, 11:21 PM   #55
I guess Homer 123's grandma will have to look for work elsewhere then.
hvac benny is offline   Reply With Quote
Old 09-03-2014, 11:22 PM   #56
Rewards Points: 484
Lol
Checking for suspected crack in heat exchanger Kozzy49 HVAC 8 12-01-2009 09:16 AM
Who to call - bad heil heat exchanger mainstreetprod HVAC 4 01-29-2009 12:19 AM
Is there such a thing as a dirty heat exchanger? suthrnreject HVAC 8 01-19-2009 09:23 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 04:57 PM
