Heil GNE075B12 Water In Teh Tube Between Combustion Blower And Pressure Switch - HVAC - Page 4 - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 11:10 AM   #46
Originally Posted by rcisguy View Post
I know this is an old thread.. But I have the same EXACT problem after replacing the combustion blower. Old blower needed replacing b/c of bearing noise and did not have any problem with condensate before. New one is producing condensate at the motor side of the tube appearing seconds after the motor starts up. Eventually a drop appears and blocks the vacuum, cycling the pressure switch/burners. If anyone could provide how or if this problem is corrected I'd really appreciate it. All the techs and installation company is clueless after contacting them, and I'm not interested in replacing the furnace as some have suggested. TIA.
do not hijack a 2 year old thread.........start your own ......thanks
dosy777 is offline   Reply With Quote
Old 02-14-2012, 04:54 PM   #47
dosy777: I'm not hijaking anything (?) I'm looking for the solution to the problem that started the thread. If the problem was solved, it would be great to see what the solution was. That's the point of these threads!
rcisguy is offline   Reply With Quote
Old 02-14-2012, 07:10 PM   #48
See my photo posted before, make the tube to go up (tie a hook in the top), so the drips of water go back into the motor. My furnace has been working fine for last 2 years! I have consulted the maker of the motor, this is ok.
Quin
Quin is offline   Reply With Quote
Old 02-15-2012, 09:20 AM   #49
Thanks Quin. It wasn't clear if that actually fixed the problem or not, but it's great to get confirmation that it did! I'm going to give this a try and keep my fingers crossed....
Are you still going with the vinyl tubing? Has it held up? Funny, your furnace looks exactly like mine, as well as the replacement combustion blower. Mine is a Fasco A172.
Thanks again.
Old 02-15-2012, 10:04 PM   #50
My vinyl tubing is good, wind from the motor has cooled the temperature down.
Old 02-16-2012, 02:02 AM   #51
how
Rewards Points: 1,070
Quin
Your solution was elegant.
I've seen a client do the same with a t fitting placed in the low dip of the tubing. The t fitting was attached to a hose that draped down into a large glass jar. The water in the jar sealed of the drain opening of the drain tube so the pressure switch could function. The glass jar in the furnace evaporated the liquid enough that he never needed to empty it. The only drawback was that he'd have to pour an inch of water into the jar at the begining of each heating season or the furnace wouldn't work.
how is offline   Reply With Quote
Old 01-04-2013, 12:46 PM   #52
Quin / rcisguyrcisguy, please confirm after the new routing of vinyl tube if you still need to drain the water out of preesure switch tube once in a while? my concern is if water flowing back to motor, it could cause damage to motor.
Your response will be highly appreciated.
Thanks,
awan is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Goodman Pressure Switch Issues taburke6 HVAC 0 11-17-2009 11:26 PM
Furnace Pressure Switch bigmatt HVAC 10 09-03-2009 07:25 PM
Trane xl90 Combustion blower Issues bjpaff HVAC 3 12-18-2007 11:00 PM
