Heil Gas Pack Burner Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2010, 09:59 AM   #1
Smile
The above image is not my gas pack, but it is very similar.
My unit has worked great for about 12 years until just last week when it shut down via the flame roll out switch (#51 on the drawing). I pushed the manual reset button on the flame roll out switch and had my wife turn the heat on inside the house.
- The powered exhaust fan comes on.
- The pilot lights.
- The burners light.
- The blower motor comes on and warm air comes out of the registers.
- It runs for about 2 minutes and then goes out on the flame roll out switch again.
One thing I noticed was that there is a nice large blue flame at the end of each of the mixer tubes (#43 on the drawing) as it goes into the heat exchanger. But there is also a continous smaller flame between each of the mixer tubes completely across the outlet end right before it goes into the heat exchanger. Most of the heat from this smaller flame goes straight up and hits the bottome of the sheetmetal plate (#42) and then the roll out switch.
Does this sound normal for there to be a continuous small flame across the outlet end of the mixer tube assembly? There is a lot of rust in there and I am thinking it may have cracked or rusted through.
Also, I call part #43 mixer tubes, but I don't really know what the correct name for it is.
Thanks for any help. I just found this forum today and it seems to have a lot of good info from experienced folks.
Howard
Another Heil Gas Pack Similar to My Unit.
Howard99 is offline   Reply With Quote
Old 11-17-2010, 08:12 PM   #2
HVAC / Plumbing
No there should not be a flame there. Make sure burner isn't stopped up
kenmac is offline   Reply With Quote
Old 11-17-2010, 08:20 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,300
Flame rollout scenarios:
Cracked heat exchanger
Heat exchanger plugged with rust (common in outdoor units) or soot
Gas valve faulty/overfiring
Recommend you get a skilled tech to find out why.
Old 11-18-2010, 04:53 AM   #4
An old Tradesmen
Rewards Points: 7,414
What Yuri said.
Old 12-04-2010, 05:40 AM   #5
I got a problem too
Hi guys, I have a gas pack (Heil) and it looks exactly like the picture with the burners at the top on first image of Howard99's post. Here is what mine is doing, what I've done and I cant think of what to do now!!!! The system began blowing cool air and just kept running while the temp in the house kept dropping. The only way to make the unit stop running was to pull the disconnect outside near the unit. When it was plugged back in both the large fan & the exhaust fan started up, but the pilot or the burners never lit. I replaced the valve (Honeywell) and nothing changed. Then I replaced the control board and still nothing changed. The thermostat seems to be working properly (it clicks when I turn it up) but nothing. If I switch the thermostat to off, both fans keep running. Even if my buddy disconnects the thermostat, they keep running. Through all this, I still have no heat, and no solution. Please respond if anyone has an idea. I will check this thread, and monitor my email. spearmad@gmail.com
Thanks, Dale
spearmad is offline   Reply With Quote
Old 12-04-2010, 05:56 AM   #6
An old Tradesmen
Did you check the roll out switches. You don't want ti to run if it has a cracked heat exchanger.
Old 12-04-2010, 06:02 AM   #7
The flame roll out switch seems to have (2) wires and I haven't found any buttons on it. I will have my maintenance friend to check it for voltage today. I had a service tech check out the firebox about 2 months ago, and he said it looked god, no cracks, in his words, very good for a 10 year old gas pack. The continuous running of the fans has me and my "maintenance buddy" dumbfounded. Thanks for your reply, Dale
Old 12-04-2010, 06:08 AM   #8
An old Tradesmen
How often do you change your air filters?
Dirty air filters can cause the heat to cycle on high limit. And since its a safety control, and not an operating control. Its not designed to last long from opening and closing. And can fail opened. And will cause your problem.
Old 12-04-2010, 06:17 AM   #9
Hvac Pro
yuri's Avatar
Yep. All manufacturers wire in the fan to run continuously when the high temp limit control opens. Needs to run to cool down the overheated heat exchanger and only when it resets will the fan stop. If it is stuck open then the fan won't stop.
Old 12-04-2010, 06:19 AM   #10
Just changed them 2 weeks ago.
Old 12-04-2010, 06:24 AM   #11
An old Tradesmen
And how long before then?
Old 12-04-2010, 06:27 AM   #12
Thanks Yuri, Both fans ran for at least 2 hours before I noticed I had no heat. The unit has been sitting for 2 days in cool/cold temps outside, has been connected several times while I'm out there freezing. Still both fans come on every time, and I have no flame. By the way, my water heater is also natural gas and it works fine, and I paid my bill!!!
Dale
Old 12-04-2010, 06:27 AM   #13
Hvac Pro
yuri's Avatar
Limit sits above the burners and probably looks like one of the round ones here
http://www.thefind.com/appliances/br...r-limit-switch
The Following User Says Thank You to yuri For This Useful Post:
spearmad (12-04-2010)
Old 12-04-2010, 06:28 AM   #14
Thanks Beenthere, One month before then, I bought my house, and the filters looked new. I checked a month later, and replaced them.
Dale
Old 12-04-2010, 06:30 AM   #15
An old Tradesmen
I would suspect that the previous owners didn't change them on a regular basis. And new ones were put in to sell the house. Evap coil may also be dirty and causing your no heat.
Units needs a thorough check out.
The Following User Says Thank You to beenthere For This Useful Post:
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Heil Gas pack: not all burners igniting cbaileyau HVAC 12 11-18-2010 05:56 AM
Bryant Gas pack Burner problem mswirtes HVAC 6 11-09-2010 11:25 AM
Goodman Furnace Burner issue hansim4 HVAC 5 10-08-2009 07:26 PM
