HEIL Gas Furnace Will Not Start. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-17-2008, 08:53 PM   #1
Question
HEIL gas furnace will not start.
This is a high efficiency propane furnace with AC. The AC works fine no problems there.
When the thermostat is calling for heat nothing happens. The inducer blower will not start which should be the first thing in the cycle.
I jumpered the inducer motor and it runs fine.
The transformer is ok also.
I changed out the control board with a new one but it didn't help.
This furnace has a Honeywell Smart Valve #SV9541.
Furnace model#N9MP2125J20P1
Any help or input would be very much apreaciated.
Mikeee is offline   Reply With Quote
Old 07-17-2008, 09:07 PM   #2
oops, did I do that!
Is there propane in the tank? Hold the blower door switch closed, put one lead on C, or common, one lead on W, or heat. Do you have 24 volts when the thermostat calls for heat.
Sorry...at the terminal strip on the furnace.
There should be a low gas press. switch on the gas line. Is there continuity through it?
8 Ball is offline   Reply With Quote
Old 07-23-2008, 04:43 PM   #3
sorry it took me so long to get back
Yes there is plenty of propane in the tank, but someone who worked on this furnace before me removed the gas pressure switch from the furnace. I am not sure why and the owner did not know either and the guy can't be found as the company he worked for is out of business.
But since he did this is there any other sugestions.
Thanks for your interest. Please reply.
Old 07-23-2008, 05:42 PM   #4
HvacWiz's Avatar
Rewards Points: 252
90% of the time its the honeywell smart valve that needs replace. these valves are famous for being faulty.
HvacWiz is offline   Reply With Quote
Old 07-23-2008, 09:27 PM   #5
How about the 24 volt thing? Do you have 24 volts, at the furnace terminal strip, between W and common.
Old 07-24-2008, 10:00 PM   #6
8 Ball, I am about 20 miles from the house where the furnace is located. I have not been back to check your sugestion. I do know that the transformer is putting out 24 volts though. As soon as I go there again I will check between w and c for 24volts when calling for heat. If 24v is there what should I check for next? Thanks.
Old 07-24-2008, 10:23 PM   #7
HvacWiz, Is there any way to test the smart valve before I invest in one? Thanks
Old 07-26-2008, 07:02 AM   #8
Dont forget to instal the low gas pressure switch, to remove a safety device is unacceptable. To know its gone, and do nothing about it is worse. Test all the safeties. High limit, press. switches...etc..
Old 01-14-2009, 09:25 PM   #9
heil furnace will not start
It sounds like your pressure switch is stuck closed. when the thermostat calls for heat, the first thing that the furnace checks for is to see if the pressure switch is open. if its not proven to be open, the furnace will not start. I have a copy of the service manual for your model furnace (n9mp2125j20p1) sequence of operation.
har199 is offline   Reply With Quote
Old 01-08-2015, 08:05 PM   #10
Rewards Points: 14
Thumbs up
Heil Gas Furnace will not start.
I did not notice the date on the post, but I just wanted to add my experience today in case it helps someone. The furnace would not start, but I knew it had power to the distribution blower. I checked the connections to the control board. So I concentrated on the very simple mercury switch thermostat. Voltage checked out, but it was so cold, the mercury switch could not be disconnected by moving the sliding heat selector. I simply forced the spring loaded mercury to the off side for about a minute and released. The furnace started. I still don't understand since I did not spot any capacitor. But it was 3° and I was just happy it works.
Wyle is offline   Reply With Quote
Old 01-08-2015, 08:57 PM   #11
Rewards Points: 582
why reply to a 6yr old post
Old 01-11-2015, 01:35 AM   #12
Rewards Points: 14
Post
Basically like I stated. I found this post while searching for an answer. I imagine someone else will also. Neither in this post or any other did I find the solution I posted. I tried to edit the post to make this clearer, yet I was unsuccessful. Most of the forums I found were similar in nature and most suggested costly attempts at substitution of parts. Mine is a simple, no cost solution. I have been able to keep my 19 year old Heil burning proficiently through advice and ideas on these forums and thank you all. But in general, my problems have mostly been inconsistent to replicate and usually amount to a rusting connector or a part that vibrated loose enough to lose ground. I hope thee ideas will help others.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Goodman furnace: won't start Guyver03 HVAC 2 10-23-2006 02:25 PM
start furnace without igniter??? repairrick HVAC 1 02-24-2006 09:45 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 06:10 AM
my ac keeps blowing boards on my heil furnace sally HVAC 2 07-23-2005 07:14 PM
