Old 10-01-2010, 06:12 PM   #16
An old Tradesmen
Heil Gas Furnace Not Lighting
I been up since 4:30. So it was hard to come up with something better.
Old 10-01-2010, 06:57 PM   #17
hvaclover's Avatar
smart Alec
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 10-06-2010, 09:33 AM   #18
No heat yet....I blew out the 1/2-inch condensate hose between the two condensation collector units (top and bottom), including the drain hose from the lower unit which flows to the clear drain hose outside the furnace. Still have two LED flashes (repeatedly), and I can hear a humming sound from the mother board behind the lower access panel. Is there a reset button on the board? Or, is the smaller motor/fan near the heat exchanger froze into position? (Sorry, I didn't answer sooner; I was out of town for five days). Again, thanks for everyone's help...
kasi42 is offline   Reply With Quote
Old 10-06-2010, 03:29 PM   #19
hvaclover's Avatar
Your drain is probably plugged somewhere between the furnace condensate trap and the floor drain (assuming that is the set up you have).
Every thing you need to know is in this manual with pictures to help you identify where in your furnace the part you are looking for is.
Hope this helps and we will still be here if you need more help.
Good luck.
http://icpindexing.mqgroup.com/docum...4001202403.pdf
Old 10-07-2010, 11:37 PM   #20
I removed the two hoses from the PVC tee trap and the lower well/switch near the blower. In addition, all drains/drain hoses have been cleaned and cleared per Heil installation instructions link provided. I also added 8 oz of water to prime between the condesate units. No furnace yet...Is it possible that the smaller fan that pulls in the outside air is seized after only three years? I read somewhere that this was a problem for Heil furnaces. As always, I appreciate your input and that the weather here in northern Illinois is cooperating. Thank you.
Old 10-07-2010, 11:44 PM   #21
hvaclover's Avatar
You can't tell the inducer is blowing or not?
Old 10-09-2010, 05:40 PM   #22
Nothing happens inside the furnace--including no movement or attempt for the inducer motor to start up. I can hear a light humming sound near the mother board not the inducer motor area above it (the furnace is a top blower/vent model in the basement). Thanks for helping me troubleshoot the problem.
Tags
heil led flashes
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Heil furnace has a hard time lighting dmanmtl HVAC 6 12-23-2010 05:39 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
