Heil Gas Furnace Not Lighting - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 12:27 AM   #1
My Heil furnace (installed 2007, Model EDD4X36JA2) does not light nor does small blower motor turn on, but hums seemingly from the board at the bottom by the main blower. When power is switched to furnace, LED on main board lights about a dozen times, then twice (off and on), then repeats (without stop) the two flashes. Air works fine. Is this the small fan, the igniter(s), relay switch, or the main board itself that's bad? Thanks for your advice.
kasi42 is offline   Reply With Quote
Old 09-27-2010, 12:37 AM   #2
Enough is Enough
H. A. S.'s Avatar
Does the manual have the flashing codes listed?
H. A. S. is offline   Reply With Quote
Old 09-27-2010, 09:39 AM   #3
Heil Flashing Codes
Thank you for your response. I do not have a manual that lists the fault codes for LED on the main board. Are the codes available somewhere else?
Old 09-27-2010, 01:49 PM   #4
HVAC / Plumbing
look on the back of the blower panel for the codes
kenmac is offline   Reply With Quote
Old 09-27-2010, 04:20 PM   #5
That is an ac model number not a furnace model.
hvaclover is offline   Reply With Quote
Old 09-27-2010, 06:18 PM   #6
Heil Furnace
Thanks for the information about the confusing of the AC number. Unfortunately, this is the only number on the front or inside the two access panels. It is a two-stage Heil furnace in a home 1750 square feet upstairs and approximately the same footage in the basement. Any suggestions where else to look for a model number?
Old 09-27-2010, 06:38 PM   #7
pull the top front panel off and look at the right or left side.
Old 09-27-2010, 09:21 PM   #8
Heil Furnace Model No. H9MPT100J16C1
Thanks, the only model number visible in the bottom of the furnace is H9MPT100J16C1. Is this a valid model number for the Heil furnace?
Thanks again.
Old 09-27-2010, 10:12 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,422
Yes.....
Old 09-30-2010, 07:11 PM   #10
Heil Furnacem Nidek H9MPT100J16C1, Fault Codes
The green LED on the mother board of my 2006 Heil two-stage furnace, flashes twice over and over, after first flashing seven or eight times when power is switched on. The furnace does not light; AC works fine including furnace blower. Any suggestions what the two LED flashes or why the furnace smaller blower, ignitors, and burners do not work? Thanks for your help. Model No. H9MPT100J16C1.
Old 09-30-2010, 08:28 PM   #11
HVAC / Plumbing
we've told you to look on the inside of the blower panel for the code.. I'll take a guess.. pressure switch stuck
Old 10-01-2010, 01:50 AM   #12
Fault Codes for Heil Furnace
I have checked both access panels on front of furnace; no fault codes are listed. If the two, repeated LED flashes indicate a stuck or faulty pressure switch, how difficult is this to replace? I'm an electrician but not an HVAC technician. Thanks for your reply.
Old 10-01-2010, 03:40 AM   #13
You have a a press switch closed when it should open... your dondensate drain is plugged
Old 10-01-2010, 06:06 AM   #14
An old Tradesmen
Rewards Points: 6,540
What is a Dondensate drain?
Are they on furnaces made by Don?
Old 10-01-2010, 07:15 AM   #15
Rewards Points: 292
Beenthere, tsk, tsk.
veesubotee is offline   Reply With Quote
Tags
heil led flashes
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Heil furnace has a hard time lighting dmanmtl HVAC 6 12-23-2010 05:39 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
