Heil Gas Furnace Keeps Running - HVAC - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 07:15 AM   #1
Question
Hi I have probably the original gas furnace in my house (c1969). It is a "Heil" brand. I replaced the thermostat a couple years ago and have not had a problem with that. This year when i lit the pilot light we noticed that it seemed like the fan kept running. When I went down to check it, the burner wasn't going, but the fan kept running and the temperature had gotten well past the thermostat setting. I think we had it on 69 and it was still running at 73-74. It seemed to work for a while but we did notice several times it continued to run well past the thermo setting. Another weird thing is when I would sometimes check it, and lift the metal face up to view the pilot/burner, the fan would cut off immediately. A few time I was able to make it shut just by slightly lifting the tabs out of the slot and pushing it back down. Last night we had the thermostat programmed to 65 and it was 73 when we woke up. I wasn't able to get down and check it right then, but it cut off at 73. I just took a look at it to get the brand name and type this post and noticed the movable plate that partially lifts so you can access/light the pilot was in the up position and I pushed it down. I'm not sure how long it has been like that or it it matters substantially? I'm also concerned that the pilot is running too hot. How big should that flame be? I have very little experience working with gas and am adept enough to know basic electric wiring. Suggestions?
doombilly is offline   Reply With Quote
Old 11-13-2011, 09:22 AM   #2
Rewards Points: 1,578
Try posting the model number.
A 40-yr old furnace is past due for replacement; a new one will be much more efficient depending on what you buy.
bob22 is offline   Reply With Quote
Old 11-13-2011, 09:27 AM   #3
biggles's Avatar
pilot should be covering the thermal couple rod and that fan ON/OFF might have a panel button knock it off when you removed the cover if that is what you did....do you have a SILVER covered control box facing you when you remove the burner panel HONEWELL on it remove the cover and there is a round dialed plate with numbers on it removing a panel bumping the fan control off might be it...could be getting stuck just as the furnace cools off "like this" just a panel vibration being remved knocks the fan off on these...http://www.bestbuyheatingandaircondi...ode=FLT64B2228
Tags
fan limit switch , furnace , gas , heil , pilot
Heil Furnace Won't Turn On ada5011 HVAC 1 11-02-2010 07:29 PM
Olsen furnace won't stay running DaleB HVAC 1 10-16-2010 09:22 PM
Heil furnace issue sbriggs_1 HVAC 19 12-05-2008 05:07 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
