HEIL Furnace Won't Throw Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2008, 04:30 PM   #1
Question
HEIL furnace won't throw heat
This furnace has been a problem from the beginning.
It's model NHGK050AF01 and is an attic unit.
When the thermostat is calling for heat the inducer blower will start and it sounds like the pilot is lighting, but the blower does not come on.
We've had a problem when it is cold as the condensation drain would freeze. I've checked that and actually put a small space heater on it.
After about 15 minutes of attempting to come on I get a message on the thermostat of "-AC" in place of the set temperature.
With temps in the teens it makes for chilly sleeping. :-(
FredW2 is offline   Reply With Quote
Old 12-22-2008, 05:40 PM   #2
Sounds like a bad blower motor.
SKIP4661 is offline   Reply With Quote
Old 12-22-2008, 05:55 PM   #3
ARRGGGHHH!!!!
Old 12-22-2008, 06:38 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
Does the burner actually fire up? How old is the unit. If it doesn't fire up then it is not the blower.
Old 12-22-2008, 06:40 PM   #5
I'm not sure about the burner firing up. How do I check? The unit is 11 years old.
Old 12-22-2008, 06:53 PM   #6
Hvac Pro
yuri's Avatar
Is there exhaust coming out the wall. Otherwise you need to go into the attic and look at the viewing port by the burner.
Old 12-22-2008, 08:51 PM   #7
Thanks. I'll look.
Old 11-15-2009, 07:36 PM   #8
Does anyone know what the remedy was for this situation??
vinceolsen is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
No heat from furnace. sofakingwyld HVAC 10 11-06-2010 06:24 AM
Wiring a RobertShaw 9870i to Gas Furnace & Heat Pump jerfer HVAC 11 12-21-2008 09:09 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
