Heil Furnace Won't Stay Lit. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-10-2013, 09:21 PM   #1
Heil furnace won't stay lit.
We turned up the heat at our 5 year old cottage. Our furnace comes on and the blower starts up, the igniter glows and the gas starts the flame but it runs only for a few minutes. Then the gas stops and the flame goes out as the green light comes on and blinks three times every 10 seconds. There is a trouble shooting information printed on the door that says it could be the pressure switch. I tried to blow air through the rubber tube coming from he pressure switch. It didn't fix the problem. When I sucked air through the tube I could hear a clicking sound. Do I need a new pressure switch? Also the catch had water in it. I blew it out as well but it made no difference either way.
jcatania is offline   Reply With Quote
Old 10-11-2013, 05:58 AM   #2
raylo32's Avatar
Rewards Points: 1,254
After blowing out the pressure switch tube and water did you try cycling the power to the unit again at the breaker or switch? Did you check to make sure the vent is clear?
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 10-11-2013, 06:12 AM   #3
Rewards Points: 582
if its and 80% furnace trace hose from pressure switch to inducer motor and use small wire and clean out port...ben sr
Tags
3lights , furnace , quits , switch
Heil DC90 Furnace Vaccuum switch problem? srt HVAC 10 11-05-2012 03:34 PM
HEIL Furnace Ignition Issues scjfly HVAC 1 10-06-2012 12:57 PM
Heil Furnace pilot will not stay on to light burner dwightvines HVAC 12 09-11-2012 06:35 AM
bryant gas furnace burner wont stay on. pipebender HVAC 29 11-08-2009 07:41 PM
Heil nat/gas furnace coverstion to propane autospecialist HVAC 0 10-26-2009 08:46 AM
