Heil Furnace Won't Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 10-19-2009, 04:13 PM   #1
Heil furnace won't ignite
Hi - 1st time post here. I've got a small hunting cabin in central WI that I've been having problems with.
The unit is a Heil 5000 series. Model number is a NULE75BG.
In searching the forums here, I'm thinking it's the pressure switch, but looking for confirmation.
The unit receives signal from the thermostat and the exhaust motor (or I think that's what it is) starts. The electronic ignitition starts to glow, but never does ignite. The motor just continues to run.
This problem started last winter just prior to shutting the system down for the year. At that time, I simply replaced the batteries in the thermostat and it started working again. I've tried that this year, but no such luck.
I left a couple of weeks ago and set the thermostat at 45 degrees. The unit was running fine and held temp when we arrived last Friday. Saturday evening is when it started again. Same syptoms as above, exhaust motor was running, but would not ignite. We changed the batteries and shut the unit down for a while. When we started it back up, it immediately started the exhaust motor, but again would not ignite.
Just looking for some confirmation that I may be on the right track. If so, I plan on buying the replacement pressure switch while I'm still in a major city. My only opportunity is to go there on weekends and trying to find a place that would sell parts and be open are slim to none.
I normally keep the water in service until early Dec, after our deer hunting season. But w/o an operational furnace, that is definitely out of the question.
Thanks for any input.
mjprel is offline   Reply With Quote
Old 10-19-2009, 05:45 PM   #2
If you are getting the glow bar to glow it is probably not the pressure switch. Could be a spill/limit switch or the gas valve is sticking. If you have a meter check for 24 volts at the gas valve while the glow bar is glowing. Usually towards the end of the glow bar cycle the ignition module will energize the gas valve from 5 to 10 seconds. If you read this voltage the valve is sticking or your out of gas.
SKIP4661 is offline   Reply With Quote
Old 10-19-2009, 08:30 PM   #3
Gas I know is good. 250 gallon tank w/ 65% full.
Just checked w/ my BIL who was up this past weekend. Exhaust fan is what's running, and ZERO glow.
Pressure switch still a possibility?
Old 10-19-2009, 08:43 PM   #4
GC/Master Plumber/Mech
Rewards Points: 560
Can you see if the control board is flashing a flash code and if so what is the code?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-19-2009, 09:48 PM   #5
Will do. Won't be back at the place until this weekend at the earliest.
I'm thinking of buying the replacement pressure switch, as long as it's returnable and trying that this weekend.
I only make it up there every few weekends. But it's getting closer to winter here in WI and can't afford the frozen pipes, so need to figure this out soon.
Old 10-19-2009, 09:59 PM   #6
Rewards Points: 560
I can't find the Model number you posted. Could you double check it?
Old 10-19-2009, 10:03 PM   #7
Thankfully, brother in law brought back the owners manual.
List as a Heil NULE 075BG01
Model 867.778381
Old 10-19-2009, 10:27 PM   #8
Although pressure switches aren't cost prohibitive, they rarely go bad. Do you know how to use a multi-meter? Why do you suspect the pressure switch as the culprit? The flash code is a good starting point in troubleshooting
Flashheatingand is offline   Reply With Quote
Old 10-20-2009, 04:50 AM   #9
newtech's Avatar
Rewards Points: 164
Model 867.778381
RE check the model number. No NULE listed. There is a NULK and a NULS. www.goheil.com
newtech is offline   Reply With Quote
Old 10-20-2009, 06:29 AM   #10
Hi Newtech.
Shouldn't let people sneak up on 'ya like that
How 'ya been ?
hvaclover is offline   Reply With Quote
Old 10-20-2009, 07:36 AM   #11
Looking at the spec sheet right now.
N - Model Number
U - Upflow
L - LP gas
E - Series
075 - Nominal Input BTU
B - Feature Code (whatever that means)
G - Nominal Air Flow (G=3.5 tons)
01 - No clue, not listed on the sheet
Old 10-20-2009, 03:02 PM   #12
newtech's Avatar
Rewards Points: 164
Originally Posted by hvaclover View Post
Hi Newtech.
How 'ya been ?
Good, and You? Haven't seen ya around in a while..
Old 10-20-2009, 03:41 PM   #13
Rewards Points: 292
He's been out getting his teeth sharpened in preparation for Halloween.
veesubotee is offline   Reply With Quote
Old 10-20-2009, 04:23 PM   #14
And that root canal was a bear too!
Old 10-20-2009, 05:48 PM   #15
Hvac Pro
yuri's Avatar
Rewards Points: 1,816
Can any one say Smart/Idiot valve? I wonder if he has one of those lovely devices.
Furnace fails to ignite now and then... diitto HVAC 7 11-23-2016 04:19 PM
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Heil furnace leaks gas emaxxman HVAC 1 06-18-2009 04:43 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
