Heil Furnace Will Not Start Up After Cycle - HVAC - DIY Chatroom Home Improvement Forum
Old 04-16-2009, 06:59 AM   #1
Heil Furnace will not start up after cycle
I am new to the forum but I have been trying to troubleshoot my furnace for a while now. Last year I had to replace the exhaust blower I think it is called because the motor burned up and I had no heat since it couldnt pull the fumes out. Now sometimes (although becoming alot more frequent) I have to go to the furnace and turn a (light) switch that is going to the furnace off and back on and it will start right up. I have replaced that switch and still has the same problem. any and all help would be greatly appreciated.
pcoslow is offline   Reply With Quote
Old 04-16-2009, 08:26 AM   #2
HVAC / Plumbing
Check ps switch or the tube to the switch for obstructions.. Must be trying to start and doesn't then locking out. That is why you have to reset by killing power
May also try cleaning flame sensor rod
kenmac is offline   Reply With Quote
Old 04-16-2009, 12:35 PM   #3
JohnH1's Avatar
Most furnace have a diognostic light on the curcuit board in the blower compartment. If the door has a peep hole next time it fails count the flashes of light. It can give a direction to start looking in.
JohnH1 is offline   Reply With Quote
Old 04-16-2009, 07:10 PM   #4
Heils suck that way. No light.
hvaclover is offline   Reply With Quote
Old 04-17-2009, 06:29 AM   #5
this may sound dumb but what is the ps switch and tube? and generally where may it be? thanks
Old 04-17-2009, 06:50 AM   #6
HVAC / Plumbing
pressure switch..it has a tube on it
Old 04-19-2009, 10:01 AM   #7
I checked every single tube coming off the pressure switch and exhaust fan that I saw. I was able to blow through the tubes fine. is there something I need to do to check/clean the switch itself?
HEIL gas furnace will not start. Mikeee HVAC 11 01-11-2015 01:35 AM
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Heil furnace won't start - just a click and a hum MrGookat HVAC 4 01-06-2009 07:53 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 06:10 AM
