-   -   Heil Furnace will not start up after cycle (http://www.diychatroom.com/f17/heil-furnace-will-not-start-up-after-cycle-42537/)
pcoslow 04-16-2009 06:59 AM
I am new to the forum but I have been trying to troubleshoot my furnace for a while now. Last year I had to replace the exhaust blower I think it is called because the motor burned up and I had no heat since it couldnt pull the fumes out. Now sometimes (although becoming alot more frequent) I have to go to the furnace and turn a (light) switch that is going to the furnace off and back on and it will start right up. I have replaced that switch and still has the same problem. any and all help would be greatly appreciated.
kenmac 04-16-2009 08:26 AM
Check ps switch or the tube to the switch for obstructions.. Must be trying to start and doesn't then locking out. That is why you have to reset by killing power
May also try cleaning flame sensor rod
JohnH1 04-16-2009 12:35 PM
Most furnace have a diognostic light on the curcuit board in the blower compartment. If the door has a peep hole next time it fails count the flashes of light. It can give a direction to start looking in.
hvaclover 04-16-2009 07:10 PM
Heils suck that way. No light.
pcoslow 04-17-2009 06:29 AM
this may sound dumb but what is the ps switch and tube? and generally where may it be? thanks
kenmac 04-17-2009 06:50 AM
pressure switch..it has a tube on it
pcoslow 04-19-2009 10:01 AM
I checked every single tube coming off the pressure switch and exhaust fan that I saw. I was able to blow through the tubes fine. is there something I need to do to check/clean the switch itself?
