Old 01-16-2013, 11:13 PM   #16
An old Tradesmen
Heil furnace questions
Not over fired, but could be under fired.
Old 01-17-2013, 10:34 AM   #17
So how would I go about checking that?
shoothebunnies is offline   Reply With Quote
Old 01-17-2013, 10:56 AM   #18
An old Tradesmen
Need a manometer. Or else you could clock your gas meter.
Old 01-17-2013, 02:59 PM   #19
Roofmaster
The Fan Motor Bearings are leaking because there is dust on them ?????????
Where do they get these guys from ????
" A lot of men build things, and a lot of things fall down "
Old 01-18-2013, 01:58 AM   #20
REP
Do the temp check after its been running for 10-15 minutes stright.Also smoke check the draft vent to see if its drafting ok,also after its been running for a while.If you have flex duct runs that are not perfectly stright and as short as possible,that would be a problem.Also run the furnace with the basement door open and when its closed to see if that affects the burn.I know i'm forgetting something but its late.A heat exchanger should last at least 20 years.You need to know why the metal is fatiguing .
REP is offline   Reply With Quote
Heil DC90 Furnace Vaccuum switch problem? srt HVAC 10 11-05-2012 04:34 PM
HEIL Furnace Ignition Issues scjfly HVAC 1 10-06-2012 01:57 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Heil furnace won't start - just a click and a hum MrGookat HVAC 4 01-06-2009 08:53 PM
Heil furnace issue sbriggs_1 HVAC 19 12-05-2008 06:07 PM
