Heil Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2008, 07:52 PM   #1
I have a 2 year old Heil Gas furnace. Would not go into heat mode. Jumpered R to Y/g and got fan and AC to function. R to W did nothing. Checked all safteies ok there. Jumpered power to the induced draft motor it ran and the fan prove switch made. OK I got brillant and figured a bad main board. Replaced the board and the same results. The gas valve led is lit solid (no faults) but no heat mode. I'm only seeing 15.3 volts through my safety circuit. Any ideas? Don't want to drop $350 on a gas valve if I don't have too!!!! Kevin
Kevi Jackson is offline   Reply With Quote
Old 11-19-2008, 07:58 PM   #2
is it a smart valve? try unplugging the valve connection and see if inducer will start
kennzz05 is offline   Reply With Quote
Old 11-19-2008, 08:02 PM   #3
It is a smart valve. I tried unpluging the 4 wire inducer plug and the 8 wire main control plug. Negative results
Old 11-19-2008, 08:48 PM   #4
i guess the next thing i would try is circumventing the board and see if i could power the valve directly to see if it glows and lights if so id say it wasnt the valve where did you get the board local or online
Old 11-19-2008, 10:44 PM   #5
I bought the board localy at a major HVAC vendor. RSD supply. Will probably have to call Heil tech support to figure a sure fire way to either condem the valve or find the real cause.
Old 11-20-2008, 08:25 AM   #6
Don't think they will talk to a HO directly. They don't even talk to their contractors directly for service assistance. Have to to talk to the local counter guy who is the designated "Tech Assistance guy". And that's only for us contractors.
But give it a shot any way. If they take your call consider your self fortunate.
hvaclover is offline   Reply With Quote
Old 11-20-2008, 08:28 AM   #7
If that furnace is two years old it's under a five year parts warranty. Th wholesaler owes you some money back.
Old 11-20-2008, 08:30 AM   #8
BTW the power for the inducer goes thru the smart Valve.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Furnace Problem JASPER2008 HVAC 9 11-22-2008 08:54 PM
oil furnace problem Dave80 HVAC 1 01-24-2008 07:53 AM
furnace problem captjack HVAC 8 11-23-2007 11:15 AM
HEIL 5000 Furnace Problem moore70 HVAC 5 03-26-2006 07:59 PM
