Heil Furnace Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 08:10 PM   #1
I have a Heil furnace
Model: FBF100F20A4
The pilot lights but the burners wont kick in. First the pilot lights, then after a minute or so the blower fan kicks in. The burners never ignite. I have the model with the continous retry 90 sec ignition module and the honeywell vr8204m1075 gas valve. I have checked for 24v at mv and mv/pv at the valve and good there. any ideas. also the pilot has a metal prong kinda like a 2 prong fork with the igniter and pilot orfice. everything seems okay, just burners wont light.
Margebe is offline   Reply With Quote
Old 11-06-2012, 08:14 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
If you have 24 volts at mv (main valve) and it does not open then the valve has failed closed. That S86 system and that valve are at least 25 yrs old and may be 30 so it failed from old age. I would buy a new furnace as the heat exchanger is probably cracked from age. less than 5% of those units left running where I am, most have been replaced.
The Following User Says Thank You to yuri For This Useful Post:
Margebe (11-07-2012)
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Heil Gas Furnace Ultimate II - High Limit Switch Triggering Problem hiei5 HVAC 11 07-24-2011 12:23 PM
Hvac heil furnace problem jimbflo HVAC 0 11-12-2009 09:23 PM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
