Heil Furnace Pilot Will Not Stay On To Light Burner - HVAC - DIY Chatroom Home Improvement Forum
Old 09-06-2012, 12:47 PM   #1
Unhappy
Heil Furnace pilot will not stay on to light burner
I have a 20 year old Heil furnace and the pilot light will not stay on long enough to light the burner, it continues to spark light and goes out after seconds of being on. Where do I start?
dwightvines is offline   Reply With Quote
Old 09-06-2012, 12:52 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
Start by re-posting this in the hvac forum down below. Then, if you have flame for a few seconds and then it shuts off, you check your flame sensor which can be cleaned (lightly scrubbed) with your every day scotchbrite dish pad.
Google search "flame sensor" so you know what to look for. It has one single wire to it and sits in the flame. It verifies that flame is present. If not, the unit quits trying to light, then tries again.
One option.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
dwightvines (09-06-2012)
Old 09-06-2012, 12:56 PM   #3
Old 09-06-2012, 04:17 PM   #4
Rewards Points: 1,300
Or just keep reposting in here every 9 min.
Sounds like a flame sensor problem to me. How long does the pilot stay lit? About 5 seconds?
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
dwightvines (09-07-2012)
Old 09-06-2012, 05:58 PM   #5
An old Tradesmen
Rewards Points: 7,814
Moved to HVAC forum.
Old 09-07-2012, 06:16 AM   #6
Yes it stays on for about 5 seconds!
Old 09-07-2012, 06:48 PM   #7
first thig is to clean the flame sensor. The control circuit allows the gas valve to stay open for ~5 seconds to allow the burners to light and the flame sensor to "see" the flame. The sensor is a wire-like probe that sticks out above one of the burner tubes. It needs to be clean and fully engulfed in the flame when the burners light. If there is no flame in the area of it you may need to pull the burner tubes and clean them as well.
Old 09-07-2012, 08:15 PM   #8
Rewards Points: 582
flame sensor problem...
Old 09-07-2012, 08:17 PM   #9
Rewards Points: 582
is it a honeywell smartvalve system???????
Old 09-08-2012, 07:54 AM   #10
This is not the advice you want to hear but oh well. Furnaces are like people in that the older they get the more important that yearly check up is. A 20 year old furnace in a climate that needs heat the first week in September is like a 90 year old man. Odds are the heat exchanger has cracks and now's the time to find that out instead of the dead of winter. Cleaning pilots,burners and flame sensors and heat exchanger inspection will all be performed by the tech while he's there. It's way cheaper than a Dr. visit and needs to be done once a year.
The Following User Says Thank You to Marty S. For This Useful Post:
ben's plumbing (09-08-2012)
Old 09-11-2012, 06:09 AM   #11
I exchanged the flame sensor/pilot assembly and still had the same problem! flame on for ~5 seconds and goes out no with no burners igniting! whats the next step?
Old 09-11-2012, 06:31 AM   #12
Rewards Points: 582
is it a honeywell smartvalve system?????????
Old 09-11-2012, 06:35 AM   #13
Its a honeywell gas valve VR844OP2088
Rheem 40gal water heater - Pilot won't stay light...thoughts ? anku HVAC 10 05-26-2013 02:55 AM
Williams NG furnace pilot light will not stay lit zBernie HVAC 1 12-04-2011 10:06 PM
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 04:27 PM
Heil Furnace Pilot Light Not Igniting shwank HVAC 13 10-07-2010 06:41 AM
Carrier Furnace Series 160 Pilot Light issue eastons HVAC 2 03-15-2009 02:26 PM
