#1 |
Heil Furnace - No primary ignition
Working on a Heil model NTGM075EGA2:
Flu vent blower comes on Igniter starts Pilot lights ( blue flame ) Main blower comes on Main ignition never happens. I suspect there is an issue with the gas valve, but would like to exhaust all possibilities before I buy one. |
#2 |
Hvac Pro
Does the gas valve have numbers like SV****. If so, you have the infamous "Smart valve/idiot valve" and they are nothing but trouble. Try removing and replugging the wiring harnesses carefully into the valve and see if that works.
#3 |
Gas valve SV9500M2674 .......... I guess that means lucky me.
#4 |
Hvac Pro
Yep. It could also be that the pilot burner and flame sensor/igniter combo needs replacing. They get corroded and may not produce enough signal to open the valve. 95% of the time it is the idiot valve. How old is the furnace? There have been lots of problems with some of those furnaces and their heat exchangers cracking/popping the compression rings that hold them together. (Back in a hr, got to do a PM on the neighbors furnace).
#5 |
Have previously replaced heat exchanger for cracking and broken "rivets". replaced sensor 2 seasons ago, other componets over the years. I figured it was time for the gas valve. This has been a pretty problematic system from the get go ( unit is about 15 yrs old ). Most every thing on the AC side has failed at one time or another also - pretty dissapointed in the Heil system.
#6 |
Hvac Pro
15 yrs is very good for that valve. You can replace it or with the tax credits invest in a new higher efficiency unit. The newer Heils/ICP are better. I prefer Lennox.
| Display Modes | |
| Heil Furnace Burner Problem | timothyr | HVAC | 78 | 01-18-2013 07:49 PM |
| Heil furnace leaks gas | emaxxman | HVAC | 1 | 06-18-2009 05:43 PM |
| furnace ignition troubleshooting | buju | HVAC | 22 | 01-14-2009 11:41 PM |
| Problems with new furnace..Overheating, having to reset. Furnace too big? | Tommy2 | HVAC | 41 | 12-01-2008 02:55 PM |
| New Cased Coil - Install to Furnace - PICTURES!! | hartkem | HVAC | 39 | 11-18-2008 02:45 AM |
