11-06-2011, 07:36 PM
#1
Heil furnace Model #nugk100dh08
I have a 10 year old Heil Model #nugk100dh08. Haven't had any problems with it prior to this. The exhaust inducer motor was bad, so I replaced the unit. I used the old capacitor because the place I ordered from sent me one that doesn't look like an exact match.
The exhaust blower is working now without vibrating, but I am not getting any heat. It doesn't seem to be getting any gas. I don't smell any gas.
How long after I turn the unit on should I have to wait for it to ignite?
Anything else I should be looking for?
TIA
11-06-2011, 08:39 PM
#2
ID fans are sensitive and need to be accurately replaced. They spin at different speeds (and 'pull' different pressure amounts) to close a specific pressure switch. They can spin clockwise or counterclockwise etc.
I recommend looking here to match up and ensure you got the correct replacement:
http://www.fasco.com/documents/pgs068-095.pdf
http://www.fasco.com/documents/pgs051-059.pdf
11-06-2011, 09:07 PM
#3
Purge time before ignition is usually around 1 minute. Check to make sure any pressure switch hoses are connected correctly. Maybe the inducer isn't spinning fast enough with the old capacitor.
11-07-2011, 05:21 AM
#4
An old Tradesmen
The new capacitor does have to match the old one. It just has to be the right one for the new inducer. Put the new capacitor on.
11-07-2011, 09:34 PM
#5
OK, I changed the capacitor. I took the vacuum hose off the inducer and put my finger over the hole. I didn't feel any vacuum. I sucked on the hose and then clamped it off with my hand and gas started to flow. Of course, as soon as I let go of it, it shut off again. So, I hooked it back up to the inducer vacuum port and no gas.
11-07-2011, 10:10 PM
#6
An old Tradesmen
Clogged flue or intake, clogged condensate drain or a cracked heat exchanger.
11-07-2011, 10:16 PM
#7
BeenThere, Thanks for all your help. Everything was working fine before I changed the old motor/blower. It was vibrating badly, but everything was working. I am trying not to doubt your suggestions because I have ABSOLUTELY no experience with any of this. However, I have to believe there is something else due to the fact that it was working before and if I apply vacuum to the hose, everything works.
Is it possible the replacement motor is dual purpose and there is a plug inside the vacuum port or something?
Thanks.
11-07-2011, 10:22 PM
#8
The easy things to check are the...
Check the inducer vaccum port for debris, especially since you didn't feel any vaccum from there. A bit of wire will work. I usually also check the pressure switch ports as well ( your mouth sucking might be enough to work around a partial obstruction but the inducer vaccum may not be as strong). Sucking too strongly on the line to the pressure switch can also ruin the switch.
11-07-2011, 10:34 PM
#9
An old Tradesmen
Doubt there is a plug. Are you sure its sealed right.
The Following User Says Thank You to beenthere For This Useful Post:
11-08-2011, 06:26 AM
#10
Checking the stats of the older fan and the newer fan should provide good info.
See my earlier post. You may have been sold a new fan that can't do the job.
11-10-2011, 12:15 PM
#11
Thanks for all your help, especially BeenThere. Apparently there are two vacuum ports, one by the intake and one by the exhaust. I had it plugged into the wrong one. Got it running this morning just in time for our cold snap here in Memphis this week. (My apologies to the people in the Northeast who have had no power for being such a wimp in my 50 degree weather).
Thanks again.
11-10-2011, 04:07 PM
#12
An old Tradesmen
Thanks again.
You are the only person in the world that has ever connected the hose to the wrong port. LOL...
Hate when I do that, it makes me scratch my head too much. And I don't have but a few strands of hair left on my head.
Glad you got it resolved.
11-10-2011, 05:39 PM
#13
Hvac Pro
I have the same problem. Saves on shampoo though.
There may be an orifice plate on the back of the inducer, make sure it is installed properly. On the high efficiency condensing units they are notorious for breaking off.
"Cut it twice and it is still too short". To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
12-11-2012, 03:55 PM
#14
Well, it's been a year and I am at it again. Same furnace. When I turn on the thermostat, the blower comes on immediately and I am not getting any gas to the burners. Any ideas on where to start would be appreciated.
12-11-2012, 06:20 PM
#15
can you show us picture of old inducer and new inducer////ben sr
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
