Old 11-02-2008, 11:46 PM   #1
HEIL furnace keeps kicking off reset switch
My furnace works fine for about 4-5 minutes. If it has to run longer than that it seems to kick off reset switch and after I go to furnance and reset the switch it works fine. The problem is when it is fairly cold outside the furnance has to run longer to heat up house and that is when it kicks off the reset switch. What is the problem?
sunsetacres1318 is offline   Reply With Quote
Old 11-03-2008, 01:08 AM   #2
HvacWiz's Avatar
Is this a oil furnace or gas?
HvacWiz is offline   Reply With Quote
Old 11-03-2008, 03:58 AM   #3
Journeyman
What reset switch are you resetting? You should never keep resetting a manual reset with-out finding out what the problem is. They are there for a reason.
pipefitter636 is offline   Reply With Quote
Old 11-03-2008, 09:37 AM   #4
hvaclover's Avatar
Hey 636! No Union guys allowed
What brings you here from the Great City Of Detroit my hvac colleague?
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 11-03-2008, 04:10 PM   #5
Journeyman
Smile
Well if no union guy's are allowed then i will have to go. j/k Just found this site and I find it interesting
Old 11-03-2008, 06:29 PM   #6
Gas HEIL dc 90
Old 11-03-2008, 06:59 PM   #7
HvacWiz's Avatar
Ok so now we know its gas, What do you keep reseting to get furnace to run.
Old 11-03-2008, 07:07 PM   #8
It is a small reset button located between to small wire connectors. These wires run to the housing of furnace and are attached to a small 4" x 2" plate that is attached to furnace housing. It seems to me that anytime the furnance has to run for long period of time (Colder out) it kicks off. If it only runs for 3-4 minutes to heat house it is fine. Filter is new, cleaned vents.
Old 11-04-2008, 09:35 AM   #9
30 year tech
hvac122's Avatar
It sounds like your re-setting a limit switch. These are there for safety and should not be reset without finding out what is causing it to trip.
When was the last time the furnace was checked by a pro? I would have this done and not take the chance with your family. There are just to many reasons for it to trip and it really needs repaired.
hvac122 is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 11:57 PM
Furnace Transfer Switch... caseywa HVAC 16 02-18-2008 10:14 AM
HEIL 5000 Furnace Problem moore70 HVAC 5 03-26-2006 08:59 PM
