-   -   HEIL furnace keeps kicking off reset switch (http://www.diychatroom.com/f17/heil-furnace-keeps-kicking-off-reset-switch-31109/)
sunsetacres1318 11-02-2008 10:46 PM
My furnace works fine for about 4-5 minutes. If it has to run longer than that it seems to kick off reset switch and after I go to furnance and reset the switch it works fine. The problem is when it is fairly cold outside the furnance has to run longer to heat up house and that is when it kicks off the reset switch. What is the problem?
HvacWiz 11-03-2008 12:08 AM
Is this a oil furnace or gas?
pipefitter636 11-03-2008 02:58 AM
What reset switch are you resetting? You should never keep resetting a manual reset with-out finding out what the problem is. They are there for a reason.
hvaclover 11-03-2008 08:37 AM
Hey 636! No Union guys allowed:)
What brings you here from the Great City Of Detroit my hvac colleague?
pipefitter636 11-03-2008 03:10 PM
Well if no union guy's are allowed then i will have to go. j/k Just found this site and I find it interesting:yes:
sunsetacres1318 11-03-2008 05:29 PM
Gas HEIL dc 90
HvacWiz 11-03-2008 05:59 PM
Ok so now we know its gas, What do you keep reseting to get furnace to run.
sunsetacres1318 11-03-2008 06:07 PM
It is a small reset button located between to small wire connectors. These wires run to the housing of furnace and are attached to a small 4" x 2" plate that is attached to furnace housing. It seems to me that anytime the furnance has to run for long period of time (Colder out) it kicks off. If it only runs for 3-4 minutes to heat house it is fine. Filter is new, cleaned vents.
hvac122 11-04-2008 08:35 AM
It sounds like your re-setting a limit switch. These are there for safety and should not be reset without finding out what is causing it to trip.
When was the last time the furnace was checked by a pro? I would have this done and not take the chance with your family. There are just to many reasons for it to trip and it really needs repaired.
