Old 10-21-2009, 07:47 AM   #1
Heil Furnace Info
Hi, I have an old Heil furnace but I do not see a mfr date on it. Can anybody help? Model #96732, VG-105AFR. Any help would be appreciated.
Bear63 is offline   Reply With Quote
Old 10-21-2009, 04:08 PM   #2
Hvac Pro
Heil Furnace Info
Do you want to know the age of it? If so look carefully at the gas valve with a magnifying glass. Find a 4 digit set of numbers. Ie 9610, usually means made in 10th month of 1996 etc.
More On This Topic
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be replacing our air filter. Before we replace our air filter, we want to take a close look at some of our intake ports here for our air into our carburetor. You want to make sure... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to change a furnace filtger. Before you move your filter, you want to make sure and note the direction of air flow. It should be indicated by an arrow on the filter... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will be removing the air filter. On this particular lawnmower, our air filter is located right here. Typically if you follow that fuel hose down, that will go into our carburetor and air... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
heil furnace sutcha HVAC 8 11-10-2009 08:20 AM
Heil Furnace Burner Problem timothyr HVAC 65 10-26-2009 04:49 PM
Heil furnace leaks gas emaxxman HVAC 1 06-18-2009 05:43 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
