Heil Furnace Gas Shut's Off & On - HVAC - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 05:50 AM   #1
Heil furnace gas shut's off & on
I just bought a house and this is first winter in it. My furnace seems to work fine with keeping house at temp. And my bill is alot lower than most neighbors but I'm single and keep temp on 68. My question is when furnace is running the gas shuts off and on. The furnace doesnt start new cycle the gas will just burn for a bit then shut off and then a few seconds later the igniter will glow and the gas will start flowing and then start burning for abit. The fan never shuts off, the flame just burns and then goes out over and over. Is this normal???
I put a new igniter and flame senser on it and it made no difference
mkmoony is offline   Reply With Quote
Old 12-15-2011, 06:06 AM   #2
Not normal. That's what a furnace does when it's overheating. Perhaps the old owners didn't change the furnace filter often and the AC coil on top of the furnace is dirty.
The Following User Says Thank You to Marty S. For This Useful Post:
mkmoony (12-15-2011)
Old 12-16-2011, 09:09 AM   #3
Thank you for your reply. But I tried a few things like I checked a-coil and it was very very clean, I put a jumper wire in the three sensor's that was on the furnace and nothing changed. I checked all the wires for good connection on mother board and still nothing. Don't ask me why but I was just standing there thinking about how much a repair was going to cost when I reached down and took the rubber hose off that goes from exhaust blower to a module that has a cple of wires coming from it. I blew through it and I could tell I blew something out of it. I put it back on and it seems to be working fine. Could somebody tell me if that could fix problem and why??
Old 12-16-2011, 08:43 PM   #4
Rewards Points: 582
seem like if something came out of the tube then that could have been tripping pressure switch on and off....that would explain burnners comming on and off with inducer still running...
Old 12-16-2011, 11:24 PM   #5
biggles's Avatar
bug rolled in there maybe the tube wasn't proofing the induced draft fan mounted above the burner so the silver disc with 2 wires was doing its job....tripping the gas..restarting...etc.anytime you see a short cycle like that re-ignition relite it that PSI proof.when your statcall the first item to run is that smaller induced draft fan then the PSI proofs air to the burner and away you go.
Old 12-17-2011, 07:20 AM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
that is a common problem with those units. water condenses inside there and starts to fill it and trip the pressure switch. once a yr/in fall remove it and blow thru it.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (12-17-2011)
Heil Electric furnace tripping breaker chrishosley HVAC 31 02-26-2013 06:35 PM
Furnace makes squeaking/rattling noise after burner shuts off Red Squirrel HVAC 10 11-12-2011 10:39 PM
Heil furnace problems nj1984 HVAC 7 10-22-2011 01:52 PM
Furnace continues to run after system shuts down spikesnet HVAC 38 10-21-2011 08:23 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
