Heil Furnace - Filter - HVAC - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 09:23 AM   #1
I am 2 months into my first time home buying experience. So far, so good. That is, except for one little problem. The furnace. It runs fine, knock on wood. The problem is that when it comes to changing the filter I can not access the filter. The way that it is positioned inside of the closet, when I remove the access panel there is a pipe (out-going gasses? is assume) that prevents access to the filter.
Any ideas? I'm not really comfortable removing this pipe that leads up to the flue pipe. Is there a flexible filter product that I could shimmy up there and support with a bracket? Just got all of the vents cleaned in the home, don't want to dirty them back up.
Thanks!
adbolton
adbolton is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Rigged my furnace for a different type of air filter, bad idea? mibson HVAC 9 01-16-2011 12:11 PM
Heil Furnace issues KMV HVAC 5 12-09-2010 01:37 PM
Furnace minus filter dsal HVAC 16 02-24-2008 12:26 PM
