Heil Furnace Fan Motor. - HVAC - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 08:05 PM   #1
Heil furnace fan motor.
The fan motor fails to start or run when the AC compressor unit is operating.
The fan motor fails to run in the thermostat 'auto' position and 'on ' position, however,
Moving the Black wire fan lead to 'cont' on the circuit board will make the motor run and stay running.
Bad board or broken wire from thermosat to furnace control module?
sidm is offline   Reply With Quote
Old 05-24-2012, 10:34 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
The proper way to check would be with a voltmeter. I would bet that the relay in the control board has failed.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Furnace motor speed change Bob Ticknor HVAC 2 12-08-2011 05:32 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
heil 9000 draft inducer motor replacement tg1 HVAC 1 11-26-2010 04:02 PM
Heil furnace won't ignite mjprel HVAC 24 10-23-2009 03:52 PM
