Heil Furnace Exhaust Fan Replacement DIY? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2008, 07:15 AM   #1
Heil furnace exhaust fan replacement DIY?
My exhaust fan motor has gotten really whiny on my 10 year propane Heil furnace. It looks very easy to replace. There are 4 screws holding the whole unit on and 3 wires to disconnect (a ground and a plus and minus). Also there is a rubber coupling tube on the exhaust pipe. Is this a fairly simple fix as it appears to be? Are there any safety steps to take first? centervilledon
centervilledon is offline   Reply With Quote
Old 12-29-2008, 10:06 AM   #2
If the fan is making noise it's probably time for an overall inspection of the unit anyway. I'd call in a HVAC guy to replace the fan and do a full service call. But to answer your question if you do decide to do anything make sure all power and gas is turned off to the unit before doing anything. I'd start in the morning on a weekday and have the phone number for a local hvac guy handy. Sounds simple - might be, might not. It would really stink to have your heat out for a night in December. Best of luck and let us know how it turns out!
Skipperjj is offline   Reply With Quote
Old 12-29-2008, 11:42 AM   #3
Res Ipsa Loquitur
I have replaced mine (Kenmore/Heil-Quaker 92% efficiency) twice since installed 1990. If yours is like mine- a gray or black pvc fanbox about 8" in diameter (shown) lying flat connected to a 2" pvc exhaust pipe and a 1.5" intake hose. What happened is that the fan turbine warped then comes in contact with the housing which melts or scrapes by friction as it is a high speed fan.
There is a low voltage sensor which is relocated to the new fan, a rubber suction tube which is simply placed on the new fan and a few wires to be one-for-one replaced. A suggestion before you do anything- always shut off the power and take a few digital pictures for reference before you remove anything both for the hoses and also the electrical connections. In my case there is not any need to turn off the gas to the heater but you might feel safer if you do.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
Tags
furnace repair diy
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
