05-21-2009, 01:21 PM
#46
HVAC / Plumbing
Heil Furnace Burner Problem
the orifice is the hole.. It's there. Have you been able to tell if you are getting any gas out of the pilot tube with it disconnected from the pilot ??
05-22-2009, 07:57 AM
#47
I did not turn the heat on while the igniter-sensor-pilot gas feed unit was not mounted by the main burners. How could you tell if gas was coming out other than lighting it? Would you hear it or smell it? How dangerous would it be to turn the heat on with the tube disconnected? Would it be smarter to disconnect the pilot gas feed tube right at the gas valve away from the igniter and sensor? Here again, would you smell the gas or hear it? Donaldb
05-22-2009, 08:02 AM
#48
HVAC / Plumbing
Originally Posted by donaldb
I did not turn the heat on while the igniter-sensor-pilot gas feed unit was not mounted by the main burners. How could you tell if gas was coming out other than lighting it? Would you hear it or smell it? Would it be smarter to disconnect the pilot gas feed tube right at the gas valve away from the igniter and sensor? Here again, would you smell the gas or hear it? Donaldb
Yes ,Yes ,Yes
be ready to kill the power just when you hear the gas come out of the tube at the valve.. It will be a small amount. But , just don't let it blow & blow, Turn it off as soon as you hear it
Of course, the safest way would be to install a gauge at the pilot port.when the pilot valve opens you will see it on the gauge.. You will need a gauge that measures inches of water column gas pressure....be safe however you check it
05-22-2009, 01:35 PM
#49
Thanx, I may try to get a soft plastic tube a foot long or so, that will fit tightly into the opening at the valve where I take the pilot feed tube out of. The gas then would be coming out a foot away from the furnace. I can't imagine an danger that way. And I would be ready to flip the switch. If nothing comes out would that mean I have a bad smart valve? Donaldb
05-22-2009, 04:08 PM
#50
HVAC / Plumbing
Well check all your limits, pressure switch, connections at the valve.imop, These valves have had more problems than any other valve on the market
05-22-2009, 08:03 PM
#51
I'm afraid you are talking way over my head. I don't know what you mean by limits, or what a pressure switch is or what a valve.imop is. Thanx for the advice anyhow. I guess I'll have to just break done and call someone. Donaldb
05-22-2009, 08:28 PM
#52
HVAC / Plumbing
In my opinion ( imo). added a p any probably shouldn't have....... If you have gas out of the pilot tube . Then it's the pilot orifice. If you don't get gas out of the pilot tube. Checked all the connections at the valve. & don't know how to check the other items.... . You need to call someone
05-24-2009, 09:40 AM
#53
I took off the aluminum tube on the main valve control and stuck a little rubber tube in it and run it to a container of soapy water. When I turned on the furnace and the valve controller clicked there was plenty of gas coming out. So, I guess it has to be the orfice or the igniter. I do see the igniter glow for 10-15 seconds. Unless the igniter has weakened over the last 10 years then it must mean the orfice is plugged up. Is the orfice hard to replace? What holds it in there? I can't see how to get it out. Do you have to buy the whole unit? Donaldb
05-24-2009, 10:04 AM
#54
HVAC / Plumbing
If I remember correctly. The orifice spud id stamped steel. It's probably rusted in place. You may tear it up getting it out. If the ignitor is glowing it should light with gas.. You will probably have to buy the pilot assy.
05-24-2009, 11:15 AM
#55
Before I buy an orfice or an assembly I wonder if it is possible that the pilot is burning and that I just can't see it? I see the glow of the igniter but I can't really tell how far down in it is. If it isn't too expensive, I could just go ahead and replace the whole assembly which would include the sensor, ignitor and pilot orfice. Do you know of anyone that handles that assembly. I've been doing some searches but haven't found a good company yet. Donaldb
05-24-2009, 01:28 PM
#56
I can't seem to find a place to buy a igniter, sensor, orfice assembly. Do you know if anyone handles that assembly? Its a Heil DC90 ultra high efficiency furnace. Donaldb
05-24-2009, 09:58 PM
#58
I also had found that site, but the combination set-up looks a little different from mine and it didn't say it would work on a Heil funace. I may give them a call on Tuesday to see if the combo unit will work on my furnace. That sounds like a very good deal. Donaldb
05-24-2009, 10:52 PM
#59
HVAC / Plumbing
All the smart valves use the same pilot assy.
05-25-2009, 01:50 AM
#60
Good, I'm glad to hear that. It just seemed odd to me that at a different site I found an igniter alone for about $80! And on this site http://www.allpartsgrills.com/productCat99580.ctlg you get the igniter-pilot-sensor for $34.65. Thats a lot of difference. I will still call them on Tuesday to make sure it will work on my furnace before I order the unit. Thanx kenmac Donaldb
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
