Heil Furnace Blows Fuse Running Vent Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 10-30-2012, 12:10 PM   #1
Heil furnace blows fuse running vent motor
I have a Heil (ICP) gas furnace/AC installed 5 years ago. The unit is blowing the 5V fuse when it gets a call for heat. The AC side works fine. The air circulation system works fine.
When the unit calls for heat, the vent motor spins up, then down 4 or 5 times then the 5V fuse on the control board blows.
I have tested the system with another thermostat; no change
I have checked the exhaust vent for blockages; none
I have checked the vent motor housing for blockages; none
I have tested continuity on the vent motor; good
I have replaced the vacuum sensor switch; no change
I have inspected the wiring for a short, to the point of dismounting the circuit board for better access; none found
I am trained as an electrical engineer and can usually tech anything, but this one has me stumped (and cold! )
My heating/AC guy has looked the system over and can find nothing wrong either.
Scrod is offline   Reply With Quote
Tags
5v fuse , gas furnace , vent motor
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
New Bryant Gas Furnace - Fuse Keeps Blowing DIYerIT HVAC 2 01-08-2012 04:22 PM
Fan motor for XE1200 Trane no running but have a frustrating problem spg112357 HVAC 13 01-08-2012 03:54 PM
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 03:59 PM
comfortmaker furnace; i've done the hard part by taking the blower motor out Hurell HVAC 2 06-05-2010 01:03 PM
