Heil Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-04-2005, 02:55 PM   #1
Heil Furnace
I am servicing a Heil gas furnace model # H9MPD125L20A2 that isn't cooperating. When I first found the unit the gas valve was not working. I installed a new gas valve and the unit fired and ran for aprox. 3 min. The unit then shut off and started clicking. I found the clicking noise to be the transiton box pressure switch assembly. I replaced this and the unit fired and once again went out after about 3 min. and started clicking again. The unit will run perfectly with the switch on the left of the assembly bypassed, but I know there is something causing the swich to trip. I can't find any ventilation problems. Anyone have an idea?
Jeff is offline   Reply With Quote
Old 02-24-2005, 06:09 PM   #2
If the switch you are talking about proves venter operation you are not venting properly. shut it down and get a qualified tech. That switch is a safty switch.
rabadger is offline   Reply With Quote
Old 03-27-2007, 12:45 AM   #3
heil furnace
Jeff
If this furnace is one of the high eff. and vents on pvc make sure that the vent slops away from the unit so that there is no codensate build up . Also make sure there is no more than 3 elbows or it will create to much backpresure and it will not run properly . Hopefully this helps.
timm6372 is offline   Reply With Quote
Old 03-30-2007, 10:27 PM   #4
Diesel Fitter
Rewards Points: 150
a good rule of thumb is less than 25' and no more than 3 90's, I use long sweepers as my 90's the older units had a drip leg on the trap but the units ive seen now do not have the trap system
mikemy6 is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
heil furnace bbr67 HVAC 5 02-24-2007 12:22 AM
HEIL 5000 Furnace Problem moore70 HVAC 5 03-26-2006 07:59 PM
my ac keeps blowing boards on my heil furnace sally HVAC 2 07-23-2005 07:14 PM
