Heil Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 11:45 AM   #1
heil furnace
code says my pressure switch is stuck open. how do i fix this
bhench is offline   Reply With Quote
Old 10-23-2011, 11:46 AM   #2
HVAC Tech/ Browns Fan
You have pvc pipes?
Tator1076 is offline   Reply With Quote
Old 10-23-2011, 11:47 AM   #3
I mean it a 80 or 90 %
Old 10-23-2011, 12:36 PM   #4
biggles's Avatar
if the induced draft is running tap it with a screw driver check the tubing going into it for water moisture....
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Heil Furnace issues KMV HVAC 5 12-09-2010 01:37 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
