Heil Furnace ? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 11:28 AM   #1
heil furnace ?
have a two year old heil propane furnace. the fan will kick on to clear the camber and run for 3-5 minutes and then shut down and not fire. wait a few minutes and it will do the same thing. then it will start again and then run properly.
put three different thermostats on to make sure that wasn't the problem. my furnace guy is stumped
any ideas?
grizzlyadams73 is offline   Reply With Quote
Old 04-09-2011, 11:40 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,230
Does it give any error codes in the viewing window? If so what are they. Is your tank full? seriously, when it gets too low the pressure drops.
Old 04-10-2011, 06:47 PM   #3
the tank has 50% in it. will have to go and get the model # of it. there is not a place to display codes
Old 04-10-2011, 07:14 PM   #4
HVAC / Plumbing
sounds like ps isn't making up / closing. Also check exhaust for blockage. Should be an led light on the circuit board in the blower comparment area
kenmac is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Heil Furnace issues KMV HVAC 5 12-09-2010 01:37 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
