Old 10-22-2009, 11:34 AM   #1
Delusional know-it-all
Default Heil fan runs continuously
Help ! I have a Heil DC90 furnace, installed in 1997. Whenever the power is on, both the draft inducer blower and the main blower come on immediately, and contunue running, until I shut the power to the furnace off. The burner never comes on, and it makes no difference what the room temperature is, or what the thermostat is set to.
I suspect that either the limit control or the control board is bad.
Can anyone tell me how to test those parts, or have any other ideas?
TIA
Gone Fission is offline   Reply With Quote
Old 10-22-2009, 06:49 PM   #2
Master Plumber/Mechanical
The high limit is a normally closed limit and you can test it by ohms or continuity.
You should have a low ohm resistance or you should have continuity through it
How dirty is the filter?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-26-2009, 09:16 PM   #3
The filter is not very dirty, it's about 8 months old, and the furnace is only used to heat a garage, so it really only has about 3 months of use. Which one is the limit switch? The one with the two red wires, behind the gas pipe?
Thanks.
Old 10-27-2009, 12:36 AM   #4
TIA - In my past experience it use to be that a simple thing as a blown transformer would cause the furnace blower to run continuously. I don't know if you tested that or not but you need to make sure you have your 24v.
Potastew is offline   Reply With Quote
Old 10-27-2009, 07:56 PM   #5
Thanks for the tips !
I have 28 volts (no load) coming out of the transformer. When I dosconnected the wires from the transformer to test the voltage, and turned the power on, the fans did not run.
There is no continuity between the two terminals of the switch behind the gas pipe (in the picture), where the two red wires go. Is that the limit switch, and is it supposed to have continuity at room temperature?
Old 10-27-2009, 08:02 PM   #6
That is a limit but a roll out limit. It should have contuity. In between the two wires there should be a nipple sticking out. Pust it in to reset.
If that limit tripped then you need to consider why it tripped. I have never seen a roll out go bad always a problem. Some of the possibilities are cracked heat exchanger and high gas pressure. If you reset the switch you need to have it checked out.
Heil is an ICP product and I have seen several heat exchangers where the rings inside the collector box have failed. Just like a Comfortmaker RPJ
Old 10-27-2009, 08:28 PM   #7
I pressed the reset button, and the furnace works normally now. Thanks!!
My friend is a plumber/HVAC guy, but he has been out of town for a couple of weeks, on a big job. I'll tell him what I found, and hopefully, he can come out and take a look at it soon.
The furnace is in a detached garage, and I only heat it to 55 degrees most of the time. I'll be careful, and open the garage doors, when I'm going to be in there, in case of CO.
The funny thing is, that rollout tripped in the summer, not in the winter, when I heat the garage. I went out to the garage one day in late June, and noticed that the fan was running. So I just turned the furnace off, and figured that I'd look at it later. Could it have gotten hot enough in the attic of the garage, to trip that rollout switch?
Old 10-27-2009, 08:36 PM   #8
old pro
I had one of those with a cracked heat exchanger the other day. After 5 minutes of running the crack opened up and the centre burner started flame rollout and tripped the rollout switch. That switch is probably set at around 300 degF so it is hard to believe it gets that hot inside the burner box in the summer (even in Texas). If someone accidentally flipped the heat on, maybe. Probably the heat exchanger is cracked, the "metal" ICP used is "suspicous" IMO.
Old 10-27-2009, 08:37 PM   #9
It could have tripped from the heat.
I think the temp setting on that limit is 127 deg. Not 100% sure. Somewhere on the round part of the limit there is the temp setting. Very small print
Old 10-27-2009, 08:43 PM   #10
old pro
On a mid it is 300-350 degF. On a high they would expect the air to be no warmer than the entering combustion air.
Old 10-27-2009, 08:45 PM   #11
Thanks guys. At any rate, I'll have my HVAC buddy take a look at it. I already had a call in to him, and I'll give him an update. If it trips again, I won't reset it, until he checks the heat exchanger.
Old 10-27-2009, 08:51 PM   #12
old pro
The one I had was 2 yrs older than yours. Have him and you watch the burners with the front cover off the burner box carefully. After the fan comes on and it has heated up good you will see flame distortion or it coming back at you. Mine did.
Good Luck
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
More Ways to Glaze Pottery
More Ways to Glaze Pottery by Expert Village
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. Now our firing is completed, after 1100 degree Cecilius temperature we keep the furnace 1 day for cooling. Now I'm opening the furnace see this is the door and our cups... Read More »
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
Hi! I’m Jim McKelvey with Third Degree Glass Factory in St. Louis. You can check us out on the web at www.stlglass.com. Today, we’re going to learn about glassblowing for expertvillage.com. One of the secrets to making really nice glass is... Read More »
Heil 80% EFF--- Fires, runs, Shuts off!! mrfyvie HVAC 4 02-10-2009 12:21 AM
Furnace (HEIL N9MP1) fan runs steady Dave @ Kamloops HVAC 1 10-14-2007 09:49 PM
Furnace (HEIL N9MP1) fan runs steady Dave @ Kamloops HVAC 0 10-07-2007 02:02 PM
AC Unit Continuously Runs - yet it is cooling reefland HVAC 4 06-17-2007 09:04 PM
Blower fan runs continuously mgeller HVAC 5 04-19-2007 11:27 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
