Heil Electric Furnace Tripping Breaker - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 07:05 PM   #31
An old Tradesmen
Rewards Points: 6,476
Either the connections were good, or the strips are over heating.
Old 02-26-2013, 07:35 PM   #32
results
Connections were questionable after taking apart, appears to have been assembled hastily, maybe 60-70% contact. Coils tested good, however those involved on legs with burnt wires also are those in the lower middle section of airflow, that were previously glowing and they definitely show wear for the worse. Cleaned up contact points, Trimmed burned wires to clean, found a burned fuse, replaced. Been running for 3 hours no problems so far.
Thanks for all the suggestions, something tells me I'll be back before I can get a heat pump back in here.
chrishosley is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 02:47 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
