Heil Electric Furnace Tripping Breaker - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-20-2011, 03:06 PM   #16
An old Tradesmen
Rewards Points: 6,942
The blower and its housing.
Old 10-20-2011, 05:22 PM   #17
Rewards Points: 484
Have you considered installing a heat pump? Seems to me like your throwing alot of money away heating your house with straight electric.
sammy37 is offline   Reply With Quote
Old 02-25-2013, 06:47 PM   #18
Came home tonight to no heat and upon opening the furnace, I see the wires feeding 1st & 2nd sequencers have burned, the first completely burned off, the other with melted sheathing and fused to an adjacent wire. No burned fuses, no tripped breakers. I can't see the lower coils with out bulling the blower or the whole coil assy. Can anyone tell me what the likely cause is and how to go about testing?
chrishosley is offline   Reply With Quote
Old 02-25-2013, 07:51 PM   #19
Heil Elec Furnace Burned wires
Came home tonight to no heat and upon opening the furnace, I see the wires feeding 1st & 2nd sequencers have burned, the first completely burned off, the other with melted sheathing and fused to an adjacent wire. Both feeding from the same fuse block. No burned fuses, no tripped breakers. I can't see the lower coils that these two wire feed with out pulling the blower or the whole coil assy. Can anyone tell me what the likely cause is and how to go about testing?
Old 02-25-2013, 08:06 PM   #20
An old Tradesmen
Can't see pics.
Old 02-25-2013, 09:28 PM   #21
Lets try this again...PICS!
Old 02-25-2013, 09:29 PM   #22
and another
Old 02-25-2013, 09:30 PM   #23
ok sorry wrong one a second time!
Old 02-25-2013, 10:12 PM   #24
Houston204's Avatar
Rewards Points: 556
Heat is created in the poor transfer of energy.
Loose or corroded connections got hot and melted is the most common cause.
It still wouldn't be a bad idea to remove power and pull and inspect the heat strips (or have this done).
Houston204 is offline   Reply With Quote
Old 02-25-2013, 10:40 PM   #25
So i pull the unit and find a broken coil, then i can replace, rewire sequencers and not be concerned about failed/damaged sequencers or do i test them?
Why is it that the fuse or breaker or other fail safe doesn't fail before wires burn?
Seems silly to me barring any obvious defects!
Old 02-25-2013, 10:42 PM   #26
fyi there were no lose or corroded connections
Old 02-25-2013, 11:06 PM   #27
Houston204's Avatar
Rewards Points: 556
So the wire burned off and the connectors still look good?
That is unusual. Do you have pictures?
Old 02-26-2013, 04:11 AM   #28
An old Tradesmen
Generally happens when the connection was loose, or corrosion prevented good electrical contact..
Old 02-26-2013, 04:36 AM   #29
An old Tradesmen
Merged threads, so its easier for people to know whats going on.
Old 02-26-2013, 07:11 AM   #30
burned wires
The wires that burned as pictured were both on the same tap. One burned completely off at the screw connecting it to power, the other just melted sheathing for two inches or so. Wires that burned are pliable as new an inch or so from the burned areas, other ends connected to sequencers look normal, as new.
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Tripping Wrong Breaker woodworksnmore@comcast.ne Electrical 15 03-28-2008 01:47 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 03:45 PM
