Heil DC90 Limit Trip - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-17-2012, 07:36 PM   #16
Temp Rise 40 - 70 F
JohnnyV is offline   Reply With Quote
Old 01-17-2012, 07:40 PM   #17
I'm Your Huckleberry
Rewards Points: 2,270
140 minus 69 would equal 1 degree over max temperature rise ALL due to restricted return air. The limit switch is working.
Clear the returns.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-17-2012, 08:03 PM   #18
how
Rewards Points: 1,102
I'm guessing that you probably did your temp rise test with the drapes away from the return air grill & the remodel problems sorted out so you still have a furnace temp problem.
All you've determined is that your limit is working on a furnace that is running too hot.
You can clock your gas meter to see if the furnace is overfired.
See if there is a higher speed tap to use on your blower.
Check the other possible causes of an air flow restriction that have already been posted here.
or call a pro.
how is offline   Reply With Quote
Old 01-17-2012, 08:11 PM   #19
How - Excellent suggestions
Thank you again!
Heil Dc90 won't fire Wally in Va HVAC 2 11-01-2011 07:10 PM
Heil DC90, no heat GoneFission HVAC 4 10-19-2011 07:29 AM
Heil Gas Furnace Ultimate II - High Limit Switch Triggering Problem hiei5 HVAC 11 07-24-2011 01:23 PM
reset limit switch on a heil quiet comfort gas furnace hogrider HVAC 1 09-16-2010 07:49 PM
heil 9000 limit switch problem? barryatnewton HVAC 1 01-02-2010 06:44 PM
