Old 03-30-2012, 01:13 PM   #1
Heil DC 90 furnace- when heat is engaged only blows cold air through the vents
Any help would be apprciated. When the furnace is in hear mode...it ignites as I can see the flame through the little window in the compartment. The fan blows and the system kicks in. However, the furnace pushes out cold air through the vents. I changed the filter however this does not help.
nzam is offline   Reply With Quote
Old 03-31-2012, 11:32 AM   #2
An old Tradesmen
Moved to HVAC forum.
Old 03-31-2012, 11:50 AM   #3
how
How long does that flame remain on when the furnace is calling for heat?
Do you have a flashing diagnostic light that is visable through a viewing port or a grilled furnace door? There will be a legend inside the furnace (probably on the door)that will explain what that diagnostic flashing light means.
how is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Is it my furnace or my thermostat? Blows cold and can't shut it off TrilliumLady HVAC 6 12-16-2010 07:51 PM
Oversized Furnace, Undersized Return Air vents and Low Heat Output.... ?? LabRat0116 HVAC 4 10-04-2010 09:53 PM
White Rodgers 50A50-405 heat blows cold Kbrodsky HVAC 5 05-04-2010 07:19 PM
HEIL furnace won't throw heat FredW2 HVAC 7 11-15-2009 08:36 PM
