Heil 9000 Draft Inducer Motor Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 02:40 PM   #1
tg1
heil 9000 draft inducer motor replacement
I am replacing my draft inducer motor in my Heil 9000 furnace because it sounds like a bearing or bushing is going out. I went to Johnson Controls and got the reccomended replacement motor with the same volts, rpms,etc. I installed the new motor/fan and it ran great but the furnace would not kick on. I then reinstalled the old one and the furnace worked. I went to a different parts warehouse to get a replacement fan and they gave me the exact same part....so I installed that one and the exact same thing happened ...fan ran great but the furnace would not kick on. Could it be that I got 2 bad replacement parts or what else could be the cause of the furnace not working when I replace the fan. Any thoughts would be appreciated. thanks
tg1 is offline   Reply With Quote
Old 11-26-2010, 03:02 PM   #2
An old Tradesmen
Rewards Points: 6,944
Post pics of old inducer and of one of the new inducers.
Draft Inducer Blower Not Blowing- LED Blinking 3 Times rust101 HVAC 10 04-09-2013 08:44 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 02:10 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 04:56 PM
Replacement impeller and clip for Heil exhaust inducer blower iixeb HVAC 2 01-09-2009 08:36 PM
