Heil 80% EFF--- Fires, Runs, Shuts Off!! - HVAC - DIY Chatroom Home Improvement Forum
Old 02-09-2009, 05:25 PM   #1
Heil 80% EFF--- Fires, runs, Shuts off!!
Heil Model # NTG3075FBGT, Gas, Forced Hot Air,
80% exhaust into chimney, Calls for heat, Fires, and shuts off. Checked exhaust Air Switch. Checks OK. Checked 3 Roll out switches, by bypassing them, and they all check OK. It is Pilotless, and fires with a Spark igniter, and that all seems to work OK. Is my next move to check the Flame sensor,(if there is one) or what? Please help,
Mark
mrfyvie is offline   Reply With Quote
Old 02-09-2009, 05:42 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,274
How old is this unit. Post a pic of the burner area. Some of them use a combination pilot burner/sensor which is not always cleanable. I usually replace the pilot burner assembly. May also have a circuit board problem.
Old 02-09-2009, 06:07 PM   #3
Heil 80% fires, runs, shuts off
Unit was installed new around 2000
Old 02-09-2009, 09:11 PM   #4
. Your model number come up here.
I believe your board is the likeliest of culprits.
http://icpindexing.mqgroup.com/docum...4111260106.pdf
hvaclover is offline   Reply With Quote
Old 02-09-2009, 10:21 PM   #5
Union HVAC Tech.
Remove the spark igniter and flame rod and clean them with emory cloth and reinstall them.
Last edited by AtlanticWBConst.; 02-10-2009 at 01:07 PM. Reason: SITE RULES VIOLATION: Advertising Line Removed from Signature
bigMikeB is offline   Reply With Quote
furnace cycles, runs for 45-60 seconds shuts down and recycles again ronsmoneypit HVAC 4 02-03-2008 01:46 PM
Furnace (HEIL N9MP1) fan runs steady Dave @ Kamloops HVAC 1 10-14-2007 07:49 PM
