-   -   Heil 80% EFF--- Fires, runs, Shuts off!! (http://www.diychatroom.com/f17/heil-80-eff-fires-runs-shuts-off-37997/)
mrfyvie 02-09-2009 06:25 PM
Heil Model # NTG3075FBGT, Gas, Forced Hot Air,
80% exhaust into chimney, Calls for heat, Fires, and shuts off. Checked exhaust Air Switch. Checks OK. Checked 3 Roll out switches, by bypassing them, and they all check OK. It is Pilotless, and fires with a Spark igniter, and that all seems to work OK. Is my next move to check the Flame sensor,(if there is one) or what? Please help,
Mark
yuri 02-09-2009 06:42 PM
How old is this unit. Post a pic of the burner area. Some of them use a combination pilot burner/sensor which is not always cleanable. I usually replace the pilot burner assembly. May also have a circuit board problem.
mrfyvie 02-09-2009 07:07 PM
Heil 80% fires, runs, shuts off
Unit was installed new around 2000
hvaclover 02-09-2009 10:11 PM
. Your model number come up here.
I believe your board is the likeliest of culprits.
http://icpindexing.mqgroup.com/docum...4111260106.pdf
bigMikeB 02-09-2009 11:21 PM
Remove the spark igniter and flame rod and clean them with emory cloth and reinstall them.
