Old 01-15-2009, 12:46 PM   #1
heil 5000 furance
I got a heil 5000 furance not it is short cycleing on my gas valve it don't say the amps does anyone know where do i set the anticipator to on the thermostat.It is a 75,000btu
harley75 is offline   Reply With Quote
Old 01-15-2009, 01:44 PM   #2
JohnH1's Avatar
heil 5000 furance
Do you have a amp meter? Or if not .5 should be close. Are you sure it is cycling on the T-stat? Did you jump it and then it stayed running?
JohnH1 is offline   Reply With Quote
Old 01-15-2009, 01:47 PM   #3
heil 5000 furance
I got a digital and standered meter.My thermo is a lux T10-1141sa now i put my digital meter on it.Set meter to ac it showed 38.1 on the wires.Not sure if that was the right way or not.
Old 01-15-2009, 02:30 PM   #4
JohnH1's Avatar
heil 5000 furance
Not voltage Amprage. Can your meter clamp around a wire?
Old 01-15-2009, 02:33 PM   #5
heil 5000 furance
no mine is a multimeter not the clamp kind
Old 01-15-2009, 02:38 PM   #6
JohnH1's Avatar
heil 5000 furance
The .5 is just a guess unless you can check it. Again are you sure it is short cycling on the stat? Is this a new stat or a new problem with a old stat.
Old 01-15-2009, 02:50 PM   #7
heil 5000 furance
it's a new stat didn't seem to run long to heat house then shut off a few seconds later back on/off/on /off a few seconds in between
Old 01-15-2009, 03:00 PM   #8
JohnH1's Avatar
heil 5000 furance
I would start with .5 to .7 setting the higher the number the longer the run cycle
Old 01-15-2009, 03:30 PM   #9
heil 5000 furance
I found the tag it was hiding it is 3.5-4.5
Old 01-15-2009, 04:29 PM   #10
heil 5000 furance
i found a some info i don't know how true it is but is says if you valve calls for 3.5-4.5 set it at 4 one more then it draws at 3.5 to run it longer and keep it off longer.
Old 01-16-2009, 07:44 AM   #11
heil 5000 furance
My question is now the furance say 3.5-4.5 on the sticker the tag on the gas valve says 3.5-.4 and the ignitor is a honeywell 24v.So do i go by the valve tag only
Old 01-16-2009, 07:50 AM   #12
An old Tradesmen
heil 5000 furance
Your not drawing that kind of amperage on the thermostat.
Don't know what tag your reading, but its not the right one.
Even a Taco power head, only draws 1.2 amps.
Old 01-16-2009, 01:11 PM   #13
heil 5000 furance
the gas valve says on it 3.5-.4
Old 01-16-2009, 02:19 PM   #14
heil 5000 furance
can a DC ammeter hand held kind be use one the two wires on the thermo i seen that somewhere but i forget what i was reading.But if so it reads 75ma
Old 01-16-2009, 04:11 PM   #15
Dr Heat's Avatar
heil 5000 furance
.8 you will find the number on the back side of the valve you will need a mirror. its a black ink stamp
Dr Heat is offline   Reply With Quote
HEIL 5000 HVAC troubleshooting tidejunky HVAC 15 03-02-2008 05:19 PM
Heil 5000 AC robtspcr HVAC 1 02-10-2008 04:04 PM
Heil High Efficiency 5000 boman47k HVAC 5 12-14-2007 02:05 PM
The Heil 5000 Air Conditioner circlecity4u HVAC 1 05-03-2006 10:54 PM
HEIL 5000 Furnace Problem moore70 HVAC 5 03-26-2006 08:59 PM
