-   -   heil 5000 furance (http://www.diychatroom.com/f17/heil-5000-furance-35974/)
harley75 01-15-2009 12:46 PM
heil 5000 furance
I got a heil 5000 furance not it is short cycleing on my gas valve it don't say the amps does anyone know where do i set the anticipator to on the thermostat.It is a 75,000btu
JohnH1 01-15-2009 01:44 PM
Do you have a amp meter? Or if not .5 should be close. Are you sure it is cycling on the T-stat? Did you jump it and then it stayed running?
harley75 01-15-2009 01:47 PM
I got a digital and standered meter.My thermo is a lux T10-1141sa now i put my digital meter on it.Set meter to ac it showed 38.1 on the wires.Not sure if that was the right way or not.
JohnH1 01-15-2009 02:30 PM
Not voltage Amprage. Can your meter clamp around a wire?
harley75 01-15-2009 02:33 PM
no mine is a multimeter not the clamp kind
JohnH1 01-15-2009 02:38 PM
The .5 is just a guess unless you can check it. Again are you sure it is short cycling on the stat? Is this a new stat or a new problem with a old stat.
harley75 01-15-2009 02:50 PM
it's a new stat didn't seem to run long to heat house then shut off a few seconds later back on/off/on /off a few seconds in between
JohnH1 01-15-2009 03:00 PM
I would start with .5 to .7 setting the higher the number the longer the run cycle
harley75 01-15-2009 03:30 PM
I found the tag it was hiding it is 3.5-4.5
harley75 01-15-2009 04:29 PM
i found a some info i don't know how true it is but is says if you valve calls for 3.5-4.5 set it at 4 one more then it draws at 3.5 to run it longer and keep it off longer.
harley75 01-16-2009 07:44 AM
My question is now the furance say 3.5-4.5 on the sticker the tag on the gas valve says 3.5-.4 and the ignitor is a honeywell 24v.So do i go by the valve tag only
beenthere 01-16-2009 07:50 AM
Your not drawing that kind of amperage on the thermostat.
Don't know what tag your reading, but its not the right one.
Even a Taco power head, only draws 1.2 amps.
harley75 01-16-2009 01:11 PM
the gas valve says on it 3.5-.4
harley75 01-16-2009 02:19 PM
can a DC ammeter hand held kind be use one the two wires on the thermo i seen that somewhere but i forget what i was reading.But if so it reads 75ma
Dr Heat 01-16-2009 04:11 PM
.8 you will find the number on the back side of the valve you will need a mirror. its a black ink stamp
